My work car is a lease. As RedFlames says, check the fine print for over-mileage charges. Can't recall what mine are, only that its a pence per...
They should be doing. The only deduction from market rate (once agreed) should be the policy excess, and salvage value if you want to keep it to...
Any GAP payout is based on the initial purchase price of the car Vs market rate when it's written off, to cover any depreciation in value since it...
They look very similar to the Cambridge Audio Min22s I have. Tiny, really clear and very musical. No bass whatsoever though, you need a sub to go...
You can, just be aware of the changes. 3 loses £ and gains # # key goes completely to allow for the bar shaped enter. Left shift is longer, so...
Isn't that already out? Just called lawn mowing simulator.
I've not seen anything about the app being discontinued. Only that cloud subscriptions for the security stuff will stop. You got a link for...
I thought it would be pointless too. Only ended up getting one because my previous thermostat broke, and the Hive worked out way cheaper. Having...
I don't think thermostats are being discontinued. Which is slightly different from when they exited US/Canada where they killed the lot. The...
And that's when I learned a new word. :lol:
Petrichor. Only remember because I looked up the etymology.
It's actually based on a guy from Sheffield, aka "the Sheffield head". First episode of the Visible Women podcast is about PPE sizing, and they...
If it's just phones you could try a WiFi switcher app.
[IMG] There were warnings :worried:
Hiring then is a thing? :worried:
4 fewer rats under the decking, but we seem to be left with a clever one who's worked out how to beat traps.
www.hcrlaw.com/blog/working-time-many-consecutive-days-can-workers-lawfully-work-without-weekly-rest-break/ WTD is Europe, WTR is UK...
This sounds a likely culprit. These extenders usually add _EXT on the end of the relevant SSIDs, they act as a bridge rather than a mesh access...
You want the pdf linked under "full specification" on the hp site....
I'm still using a 6T as a daily driver, and still get at least a day out of the battery. It'll stretch to two with light use when I'm distracted...
