Hi, I will be deploying soon and I need a rigid mouse mat, since I won't have anything resembling a desk at my destination. I had a ratpads GS...
My vote was for Flow, but my money's on Cygnus. One vote sucks!
For those who care, here are the system specs. It arrives today! - ASUS P5Q DELUXE Intel P45 - Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA...
Hi all, This is a fairly quick project log, born out of my need to have a case that's worthy of holding my new system. I did some...
I got my black TRUE today, this thing is dead sexy. Yes, there are less expensive options, but you get what you pay for. If you saw my thread,...
I looked into it, but all the quotes I got were crazy expensive. Nothing I can do myself I suspect, as the platters don't even spin up when I...
Th at spot looks fine, as long as you have enough room behind them for the cable to plug in.
As some nice person pointed out in my thread, the q6600 is getting a bit old. If I could go back in time to Friday, I would have ordered the...
I was actually going to get the P5q-e, until I realized that the bundle with the xonar on the deluxe was actually cheaper than the e + a xonar....
Thanks for the input guys, here's a bit of my dubious reasoning on a few items. Burner - chose it b/c reviews said it's reliable, quiet, it...
That is modding perfection. Simple, yet awesome. +1
So after my Antec 500 PSU set me motherboard on fire (yes, actual fire, I saw it) last week, bricking every single piece of hardware in my system,...
Amber/Orange is the new blue.....
Why not run an ide extender cable to the outside of the case somewhere? So when you need an optical, you just plug it into the back of the case....
you could always use a stencil and paint it onto the back of the plexi as well. Would hold up just fine I think.
Did you consider wrapping the metal corners in the carbon fiber? That could look totally sweet. Love the design so far, can't wait to see a build.
I can't quite put my finger on why, but that entire release was very akward to read.
Last night, the POS 6800gt from Leadtek in my system died. I tested the card in another system and confirmed doa. So I slapped in a 9500pro out...
Anyone notice the coolermaster box in the video?
Initially, I thought only 3/8 to 1/2 and inch. But I'm worried that you're going to need to dampen the vibration of the hdd's, with only one side...
