Not sure if you have sorted this yet, but how many displays are you trying to connect to the cards? Also, how are they connected exactly?
Not really surprised by this.
Yes that doesn't sound great if it was a new item you purchased. Where was it from?
Been coming for a while unfortunately, another one bites the dust.
I haven't seen it mentioned yet, but Red Dead Redemption is a must for me. Amazing game!
It does seem strange that the card shows the same issue in two different systems, but I'm sure an obvious issue like this would show itself...
Yes things don't sound good, especially seeing that screenshot. If the other card is working fine, all signs point to that one card being faulty....
As others have said, decreasing the overclock is a good option. These cards do run hot, as expected, just ensure the room is at a decent...
Whilst these kind of games do seem appealing, you have to put quite a bit of time into them to go anywhere. That just isn't time I have anymore,...
How did you get on with this, did you end up returning it?
Yeah I agree, go into the Catalyst Control Centre and via the Overdrive section try manually adjusting the fan and as he said you should hear it...
What output are you using to connect to either of the displays? Any other outputs on the graphics card that you can try to rule out the current...
Cannot wait for this. Three playable characters should be interesting.
Try removing the graphics card and using onboard VGA if possible, or maybe temporarily test the system with a different card if that is an option.
Does seem knackered, have you tried another connection other than the one being used right now?
Really can't wait for this. Going off the bits of information so far, it could be amazing!
No warranty left on it?
Have you tried a driver sweep? Is this also only with WoW or everything?
Yes please. Is it 13?
Great end to this and good job Gigabyte.
