I really don't think flow is the issue here, the water manages to pretty much hit the top of my tank? How can flow be a issue? I don't think its...
Problem is the flow is so good its nearly hitting the top of the tank lid, so I can't leave the top off as it will spill out. I am pretty sure...
Shouldn't it be 'None ECC Unbuffered' were as it says: ECC Yes Buffered/Registered Unbuffered I just checked some RAM on scan and it all...
I am almost 99% sure it wouldn't work due to the ECC not been supported by your mobo. But as its a dell I can't tell what your mobo is.
There is a lot of room in the case for air, pipes do not cover everything and air can move around them. I would be very surprised if this is the...
I don't want to strip is down yet until I have all the idea's, but by looks of its there have run out. I really don't think flow is a issue, the...
:BUMP: Still looking for advice.
I just got a NZXT in my Cosmos build, controls 5 fans with 5 temps and works great! Sometimes I think it runs the fans a bit low, and if you set...
You see I thought coolest first as you don't want to take heat from something like CPU to the NB as it should be hotter. But as this is the first...
I hope that helps, looked at a few flow sensors but they all mention restriction. some are 'High flow' but they don't sound to good really? Anyone...
I know the black tubing and blocks make it hard, but I see loads of cases with black tubing and blocks and they looks mint. Its a trade off I...
Hi, ok so I am ready to drain the whole thing. I really need to know what you think I should check when its drained. Now talking with my dad I am...
I would say my CPU is high due to thermal paste. I get 38-35-37-36 when idle. As for the rads here they are:...
Do you think the CPU is hot too or just the GPU? The case temp with the sides off is 29c, its pretty hot in my room really. Just took the card...
Problem is to take it apart would mean draining it again, something that isn't easy in this case. Just running Prime95 with my Intel 930 @ Stock...
I am lost with this now. Just tightened the screw and it was getting to 70c, so shut it down and loosened it a little and getting 70c under load...
Hi, Ok ran if for a bit and got a max of 58c and a min of 48c. Water temp gets to 33c. Here is a screenshot of the test. Screenshot I will...
Now this is odd, I have the case side off to take some pictures for you. I started to run the Furmarks test again (1280x1024) stability test and...
I have always found Aten to be a good make. I just won a 8port VGA/USB rack mount KVM on ebay with 4 cables. Currently got a 8port VGA/PS2 Aten...
Ok, I have got it down to 70c on load and 52 idle. Now its very slowly increasing as the water temp goes up, which will slowly mean the fans...
