14.
the fractal design hp's... or might be the gp's i can't remember their name now, just that i picked them with watercooling in mind.. I quite...
My case fans are static pressure... The plan was always to water cool... It just never happened (yet)
Hey.. A few months back my cpu fan died.. I took the fan off the heatsink and I dropped the overclock off and it's been running on case airflow...
Little question... · Please include your contact details (shipping address, contact telephone number and full names) in the email. · Your...
In. :)
Do Not Change The MCB. If you can't tell me the Ze, Zs, R1+R2 and the csa of the circuit, then you can't do it without risking burning down...
I've seen a few of these, epic money making scheme for them. You are renting the roof to them for 25 years with /NO/ get out clause, to sell...
Turn off all electrics at main switch. Prove dead with your tester. Flip off all circuit breakers. At the end of the circuit you wish to...
http://www.identifont.com/identify.html
I'll attempt a repair on it if you want... You pay postage obviously. Also no guarantees, I'll do what I can, but I can't promise anything....
Is it just C2740 that you broke off? (its a capacitor btw not a resistor) there seem to be 3 sets of pads showing signs of damage to the right...
Maplins used to sell it, but they discontinued it a few years back. I still have a roll of it somewhere from when it was discontinued and the...
cpemma's site has been down for months. The circuit works well though, I use it in my pc to make the power light throb. also 45Hz-200Hz, how do...
lol @all the cut and run comments.. But yeah, seriously, do. Run fast, run far, and never look back. It may not be easy, but it is by far...
What you have there is: The wrong type of mouse.
"they just flash between red-green-blue and you have no control over them other than on/off? " got it in one :o/
wrong type of switch mate... you want momentry not latching...
Can't you add the key to your steam account? Better then a nocd crack :D
Yes, there is a way :) That was easy :) PS. you may find 'Advanced Masking Techniques' with Katrin Eismann a good watch.
