Got 4 so far. That should be enough...
A few 8TB Toshiba N300 NAS drives - Amazon warehouse 20% off Just over £100 for Used - Like New and the first to arrive was unopened. I've...
It's all going well then!
If the benchmarks are close to being accurate then that's a fair bit better than I was expecting right off the bat. I assume they will be selling...
Spoke to my sparky and the cables will be 'put in to containment, either black or white pipe' as he says external ethernet is a nightmare to work...
Thanks, I'll see what my sparky is planning on using.
We're hoping to move in the next few years to rewiring the whole house just isn't worth it. What you did is exactly what I'm planning so good to...
Yeah, this has also crossed my mind as well. No 'need' for it yet...
Upgraded to 500Mbps fibre. I think it's now time to run Cat6 from the loft room/office to the living room where the fibre modem and router are....
Interested in other responses to this thread as I'm thinking of replacing my router, which is the DSL version that you have. I have a similar use...
I have this problem as well. Such a hardship.
Good deal on the Pixel 6 preorder - Free Bose 700 headphones.
I would have thought a single 6-pin to 8-pin would do the job just fine. I would also think that the PSU would be enough, just don't try...
Had considered second hand drayteks...
They're not for me. They are meant to be for the employees of a small business who's owner I know. Two are on virgin and using superhub 3's I...
I did see that and have experience with the older 1900 model. Need the option to disable SIP ALG. QoS and VPN at the router level would also be...
Looking for suggestions for budget (£50-£75) routers to replace Virgin superhub 3's (put them in modem only mode). This is for a few people who...
Checkout Jeff Geerling you YouTube, he has some videos on running a pi nas.
This is going to be a long one but I'm looking for some suggestions. I currently have 3 servers running and a Synology NAS as well as a couple...
It's quite large for ITX but not too large. The only issue I have is that there's no easy way to cover up the cables that route through the...
