Well I always wanted to do a triple, but maybe you're right a 2x120 would be enough, i had planned an sli with a 939 amd, and the rest didn't need...
WOW NO advice at all? come on guys, need some help here... Anyhow, got my motherboard back, but realized I better wait until i can get the...
Performance-PCs.com is florida likely has the panels you need, even if not lsited on the site, try them as well...
Sorry guys, still no updates, been doing a few other things and constantly waiting for my motherboard to return (driving my mother nuts) I'm using...
[IMG] X-Acto Knife, beer and some bolt cutters (yes 2 foot bolt cutters)... It still has never seen a file or sand paper... Moral: Slap...
:waah: Oops! its the AGP bracket! :duh: :wallbash: :waah: [IMG] [IMG] Moral: Don't make mods at 3 AM with no plan and some wire cutters...
hey man if you wanna see poor case mods, i can show my mine ;]
This is not an update per se, as I don't have any picture of work to show... Well I am going to be holding off on this project until I can get...
Ok, I have done some planning and other work not related to this project, so sorry for the lack of updates... I don't want to have to remove...
Love it all, I was curious how you found G 1/4" elbow fittings for the alphacool res's, I need some
It was no longer going to be a project on just the motherboard mod, i was going to take it much further, including full water cooling the system...
What do you guys think (like anyone will reply, 200+ views, no posts...) should I keep this thread or am I wasting my time posting my progress,...
I'd hate to have a name that sounds like a fish, just my two cents......
I'm positive you can run many monitors off one pc, check into what AJB2K3 said.
I shouldn't have thrown them out :[ flight simulator? [IMG] :]
Update! I drilled out the rivets that hold in the back plate and motherboard plate in the 1200 case [IMG] and the rivets that hold the...
No man, the block does 2.0 as well, all I use is the block...
OK those are for a motherboard that doesn't fit the standard USB block, as far as I know, thats old and obsolete, I simply taped mine though...
I was lapping a PolarFLO TT and a Swiftech Apogee, neither came out great, but good enough for my needs. The trick to the 1200+ grit was DRY, wet...
Ok I bought a cpu lapping kit from FrozenCPU.com and it includes a peice of plexiglass (to provide a flat surface) sand paper (400, 800, 1200,...
