Possibly, or it could be a minor tilt and just shrink the window vertically a tad.
I'd like to see sensors like the one in the powerbook and the thinkpads used to make actual laptop-use much more fun. For instance, if I'm...
:hehe: :rock: Yeah, I had my KVM hooked up and could switch with my MX700 no problem. Worked the same on both OSes.
Actually the Mac Mini doesn't come with a mouse, if I recall right. Either way, you can buy a 2 button USB mouse and it's supported natively by...
I don't see them changing much of Tivo other than the interface with the user and yes, casing will probably be white. But I can definitely see...
The first gen G4s had jumpers to O/C. The G4s of yesteryear needed to be soldered with SMD resistors. G5s... haven't heard much on that....
Technics will be my child's first really, really cool toy. Actual Technics too, none the new style Lego BS with pre-manufactured and curved...
Simple Fix: VGA output. Seriously folks, if you put it on your console as part of the basic package, or even give it a breakout box for it...
My trick to fight the "nice guy getting jipped" situation? Business cards. With a flat "per visit" fee clearly printed in the corner, under my...
Here we go, the boys over at MP3car really helped me out with this link: http://www.talkaudio.co.uk/vbb/showthread.php?t=54203 Although...
Say I wired a 2nd battery to my car in parrallel. ...would it do anything different? What are the effects? Anything?
I used a frosted piece of plexi for a long time. Surrounded it with foam from a 50 cent mousepad and it kept the mouse in bounds and my hands comfy.
Don't forget those rich types like myself, getting a job in a freakin' stuffed animal store just to be able to show my parents I'm a responsible...
Yup. Eye and nose are what I hear.
Can't help you at the moment [ can't find the bit I hacked off, heh ] But from what I remember from making custom connectors for my PSX the...
Apple. Appppple's latest operating system. :D But yes, it's only a matter of time. I can't wait to see the equivalent of a Deltree c: esque...
Actually the Photo iPod is a bit thicker, and has a much bigger battery. So it'll go for a bit more than the others, guarunteed.
Leather, little people, and vacationing in Arkansas! :naughty: :thumb:
*sigh* This again. Nobody is reading your email. A server is scanning for keywords. Look at the bottom of the page when you reply. That's a...
If you've got 24 pins from the ATX lead on your PSU... You've bought a server styled PSU, and you need a pin converter for that. The other...
