Tentacle monster. ;D
Btw where did you find that "tube" wich you used in frame?
Ill suggest Scythe 800-series fans. I have them at my Antec P180 and they are damm good fans. They are about 10db
Hey guys i need help. Where i can buy NB block for that Intel board? Or what is mounting hole diameters? Has anyone measured em? Here you can...
Look this beaty<3 [IMG] Im just installing Windows Home Server for atom. I will test that mobo works fine and then ill swap that Zalman to NB....
But if someone has some wicked ideas about casing or how to mod it more please, you know what to do!
I mean at program :D ( Google Sketchup)
So first minor update i got plans done. And i got first problem up a head. How i can cut that yellow piece to smaller? I downloaded that...
[IMG] Welcome to watch another project from me. Children Of Atom This project will be "quick" mod like all others. Im building case for...
Damm this is gonna be hard decision, shall i buy watercooling or second computer for irc, movie computer and other small stuff (that shall be...
Back to sivilisation! First we made 2x "L" woods wich is 90cm tall and depth is about 24cm. As you can see we used thick metal construction...
Great news! I'v gonna go to build my HQ today with my friend + minor update! I found these metal pieces last summer from my ex-job place...
Yeah im desparately waiting that too... But anyways it seems that i have some extra money and i will buy budget watercooling to this.
Of course! That is hinged so you can open it easily if something ****ed up you know.
Sorry that i haven't been able to show you building pictures, there is bit problem. There is raging stomach flu in my sisters house, wich basement...
That TV would weight so much that i need to make much much much more bigger base to it :<
[IMG] Quick raw plan picture. Green switch are Zotac Nitro panel buttons, big red is show-off for bios reset and blue steel with blue led ring...
That is good question, but liek i said ill built this first and plan computer later. And im planning to wrap whole case to leather, easy, cheap...
It just a budget question and tools. Budget is for whole case 80e (that includes wallmount)
[IMG] Let me prodly introduce you to Quad Complex! [IMG] [IMG] Those 3 bottom monitors are 19" and top one is 22". Three one is connected...
