Get a squonk. 10ml tanks :D
Exam passed, now officially an Azure Solutions Architect Expert
If somebody wants friends & family "because of the fees" and not a proper paypal payment/refund it's almost always a scam. You can't reverse a...
You may want to look at a point to point link between the mane house and lodge then an AP inside the lodge. Ubiquiti do some fairly cheap ones in...
You can use the DDNS to access the VPN with a dynamic IP. VPN is definitely the safest way. Phole admin can be done via an app without opening...
Create a client VPN on the USG then VPN in to access things you need internally. You don't need to open any ports unless you want the public to...
Completed on the house & have the keys!
Check that side of the machine isn't on a seperate board that needs reconnecting. Had something similar with my old macbook pro, a lose connected...
I've got at least 20 pairs of headphones & regularly swap around depending on my needs. Airpod Pro's work well if you're already in the...
Most ATA's are similar. Grandstream or Linksys are commonly used and supported. The passthrough netgear powerline's are often on special around...
The one IanW linked to would work. In the world of SIP/VOIP trunk or channel is a virtual phone line. So a single channel/trunk would work for you
Other option for the alarm (assuming it's not using Redcare) is to get a ATA to connect it to then use something like sipgate to give it a line....
I've been working on migration stratagies on the migration with various customers for the past few years. Business was their focus at the moment...
Wireless AP's with a wired backhaul to a central switch will always be best, mesh can be better than nothing (providing the floors don't blick the...
Definitely autopilot The device needs deleting from MEM so it doesn't autoprovision
I completely missed you'd replied, sorry. That graphic EQ (if I'm reading it right) is insane,there's 24 bands there and you've not even got to...
Not an answer as such but (as somebody who swore by htpc's since 2001) getting everything to work nicely and pass the WAF (i.e. needs to all be on...
Any pics of this DSP app? Sounds list like an EQ which would be easy enough to sort.
