Great !
Same here, Skyrim lvl 40 on resume for a week for me cause of the XCOM....:)
You want to said a view options are missing ie. top view, side view etc.
I agree with all you said in the article. High-end all the way...
Sorry, 7970x2
Or maybe to wait a little extra longer for 7979x2 ;) Expect something over £600 :(
It would be like 50% more here in Croatia = £660 What do you say for that? :) Happy Christmas to all! P.S. Save a quid or two for the new...
Really? Guys at Hardwaresecrets have a different results ... http://www.hardwaresecrets.com/article/AMD-Radeon-HD-7970-Video-Card-Review/1458/14
'...the fan spun up to a gently audible level under load to keep the GPU temperature below 80°C.' Hmmmmm. I wonder what would my ears say about...
"...with the 12V lines again standing up particularly well and not dropping below 12V. One slight niggle, however, is that the 3.3V rail only...
"An efficient PSU, on the other hand, will run cooler and draw less power from the mains, which will help to reduce your electricity bill." Here...
"...we use a third-party lab - in this case, the R&D office of Antec out in Taiwan." Thumb down. You could use a real world conditions for...
"16AWG wiring, which it claims reduces conducted resistance and improves the efficiency of the PSU." Laugh. Laugh. Congratulations Antec for...
Then you should read the tutorials and watch how it's made on youtube. I've learned from these and nobody showed me live and succeeded. You shuld...
I have had it also, now I am running GTX470 with EK block. At 31°C in the room I have only around 55 max at GPU under load and no noise at all :)
No changing fluids for a year or so - fluids don't disappear. Just cleaning dust every few months more or less. Stock is good for most of the...
Go for used parts rather than a new one for CPUs and mobos. Look for used VGAs with water blocks and not for the newest. This is a best buy...
It doesn't make any difference - the heat can't disappear. But you could always make a ventilation channel to make the way for a hot air from the...
I don't expect anything spectacular to happen in future with water cooling efficiency because water or distilled water heat capacity is...
