Would it have hurt you to have written "Nintendo and Sony sued over wireless tech(nology)" or would three more button presses have been too...
I think you mean 16.8 million terabytes.
AMD claim they won't support CUDA as it isn't open source. Because PhysX is on dedicated hardware?
Does that mean that because memory usage became so large as to spill over in to the page file the OS started to prefer to give the RAM to other...
I'm not refuting or agreeing this, nor am I saying that it's changed, but the effect of memory amount and bandwidth on the "C2D" or C2Q...
Anyway PDF27, thanks for opening up an interesting discussion about something which had confused me. What is your Penguin writing?
No offence intended* and I did not direct it towards you specifically, but Bit-tech in general. No offence to Bit-tech but I have seen a few typos...
An incorrectly spelt portmanteau of game journalist? Why does bit-tech find it so hard to use spell check, maybe they don't want to be bothered by...
DAMMIT (AMD/ATI) and Nvidia have different ways of counting stream processors: AMD counts a cluster of 4 small ones (which can't do special...
Oh great, thanks for the acronym. You just reminded me of Spot the dog.
I don't know what I'm most disappointed about: the lack of higher clock speeds, the stupid model number system AMD's using which stops them...
Sorry about the synthetic but after the first several dozen reviews on different subjects most reviews seem to be synthetic (except bit-tech's...
Yay! Slides and X prefix! Though it is a bit odd that X3, according to the slides, has only a 30% improvement over X2 Athlon (indicating K8)...
2256 KiB / 4 = 564 KiB. :confused: . Should it not be [64 KiB L1 + 256 KiB L2]*4 = 1280 KiB. *It's easy being an editor* *Can't. Resist. Urge....
Thanks r4tch3t, I knew that the Intel '2 Core 2 Duo dies in one package' quad cores couldn't adjust the clock speed of each core independently but...
Does the 'Intel Extreme Tuning Utility' allow you to clock each core individually on a quad core? Same question for NVIDIA's ntune if anybody knows.
Please delete, double post.
I believe this UVD MPEG-2 debate can be explained by the AMD 7-Series Innovations slide (which also states that the SB700 is PCIe Gen 2) and by...
Just nitpicking but the 770X doesn't exist as the die (770) is the same one used in the 790X (please confirm this), the only difference between...
Who, me? Whatever could make you think that?
