http://www.bit-tech.net/hardware/2007/11/12/bfgtech_geforce_8800_gt_oc_512mb/1 All I know is AMD will be doing a lot of back peddling if this...
No review, no testing and they want the the first world to bankroll the onset of the finished product. I know the third world on average are very...
"Houston we have a problem"!!!! If this Tricore news came out a month or so after the release of Phenom it would be an easier sell but since...
Very fine and dandy relying on the mid and low end but when your high end is in fact low end compared to your two main rivals Nvidia and Intel,...
As PC Partners learned it is better to switch then fight. For those asking for lower pricing on the GTX of any make, why should they drop in price...
Why Orton would leave, well why did AMD force the launch of the HD2900 XT without independent L1 cache for 320 streaming units and then tell...
As another poster already made clear whats good for the consumer for the short run may not be at all acceptable in the long run. AMD when they...
I believe you are speaking of reverse hyperthreading where some one claimed AMD was working on a process that would allow a fully working logic...
a little off topic but there seems no new news coming out of Computex since even with the hype of Intel and Nvidia working together under new...
This is pretty funny coming from a company that has not gotten 65 NM out the door yet. I guess when you are huge as IBM is you can stand the heat...
A better example then the X1900 series would be the X850 XT PE that replaced the once imagined X800 XT PE for ATI that came months after the...
What all this is about is the delay of the R600 has had an impact upon AMD's ability to get anything new into their lineup of GPUs. By rebadging...
What it seems to me is that Intel is playing the game now of not allowing AMD any breathing room, They know that Barcelona may be launched in...
Now this was one sweet write up for AMD, AMD promises not to try to break Intel's integrated graphics strangle hold on motherboard if Intel plays...
For those that believe it is a strategy move that the R600 is delayed, then you must have believed that the yr late launch of the PS3 after the...
Speaking as one of the uninvited guest that you scorn, I would say your opinion is yours and are able to have it but it is not reality outside of...
Did you ever wonder that some of your problems could have been Vista 64 bit related? I have to wonder about someone that would use 32 bit...
I believe we will see this Dram used in systems that consumers do not need high performance say the $1000 and below category or on divisus like...
You are correct but all the same being able to use true 200 MHz quad pumped would still be faster than using a lesser bandwidth FSB which was part...
"By the looks of it, the chip we have here sucks and many have fared better" When has it ever been said that + 1.35 GBs stable that you where...
