Which of the abit.asus boards would you recommend? As im not looking for sli, but dont wanna be upgrading anytime soon either! lol God...
The thing is with a 3000/3200 venice, core i would like a decent overclock once im bored with the upgrade!! Will both boards be up to the task,...
Ive been looking at the DFi, and asus boards, but are there any others you would recommend? As im stuck on the differences!! as the dfi has...
I have the choice of a socket 754 cpu, 3200 clawhammer, 1mb l2 cache 3200 newcastle , --- 2450, been too pros and cons etc??? all on...
Im just lookin for a new cpu, and came acroos mobile amd64 cpus. And was wondering wether there was any advantage over the nrmal ones. As in...
I have a plugin that supposedly shows up photo informations, such as Focal and ISO But i do not know how to install it in photoshop and how to...
Anyone?
Is there any significant differences between the two? Also any advice on a motherboard, looking for NF4 probably, or nf3, but not to intersted...
Do you think they work? Ive just joined this one! Hoping that more will join under me to see how the chain works!! What do you think?...
So how come screens like this are used for sat nav? In normal car installs with no car pc?
Is this s-video or composite connection? AS i cant get vga The photos are gr8, what is the actual monitor? THANKS AGAIN
How crappy is crappy? As dvds and video should be ok? Also this is from an in car tv, pioneer i think so was not cheap!! And these...
Cheers is this and compositie connection? Cam i ave a pick of winamp full screen and some text like different size fonts? CHEEKY!!
Can some one get a pic of winamp on full screen? So i can see if the text is good? The screen il be using is 6.5" wide, so the it should be...
Could you read txt in winamp etc on the playlists?
Any pics of the screen and text clarity?
[IMG]
I have a screen with the usual yellow video out, i can easily change to s-video with a cable But i was wonderin whether converting to vga would...
Would it be possible to seperate the navigation buttons or F1-F12 off of a keyboard and cahnge the commands, for something like music control?...
Ignore the infra red remote, does any one have information on remotes that are wired? USB Serial Parellel Either custom ones or pre made,...
