I will give that a bash, cheers
I upgraded a small network to windows 8 over the weekend, after doing 2 of the computer I was able to connect to the printer automatically...
thanks for the advice thing is it actually runs VIA audio probably cos it has a nvidia chipset
in order to fix the problem or just to stop audio coming out of the speakers
when i plug headphone into my front jack my computer will play audio through my headphones and my speakers at the same time instead of switching....
i had a debate with manager at work today about hdmi cables i say cheap are as good as expensive and he says vice versa, because he went to belkin...
Lack of RAM shouldn't cause high CPU usage
no it is happening all of the time and the pc is running very slow i use eset on my gaming pc, everyting else runs kaspersky
hi my compaq presario is running very slow and kaspersky pure is using 98% of the cpu. my specs are:- Intel Pentium D 820 Dual Core...
hi i was playing f1 on my pc and i alt tabbed, i noticed that a dialog box had appeared "windows has detected a fault with your hard drive",...
hi i would buy Pentium g6950 gtx 450 top 4gb ddr3 ram gigabyte ud2 mobo samsung spinpoint f3 1TB thermaltake frio cooler razer arctosa...
why not get a drobo for the file storage as it has redundancy and is very easy to upgrade hard disks
i use last pass, it will recognise form names and autofill information into text boxes, it will even save passwords to the cloud so i can access...
it only seems to work when i am signed in but it is pretty cool
i have the acer a110 16gb ssd with windows xp on it, i had to put some software called flashfire on it to make it faster now it really good i also...
whenever i play blur the first 2 levels of the first "boss" work perfectly but after that the game will freeze and the display will go into "power...
i recently installed hackintosh on a seperate partition on my hard drive which manged to remove windows 7 from the boot loader, i managed to...
i have been trying to install hackintosh on my system(specs in signature) but whenever i get to the gui to install there is no mouse or keyboard...
i think if i put silver mesh over the fans they would become useless. i am using a power supply with the green cable earthed so the psu turns...
no, it is attached to the screen using blu tack:rock:.
