haha, wow, it has been a while!! I havent really modded any comps in all that time :| Sorry to say this designers, but Im not sure I like...
Wow, this place has grown so much since I last visited. I learned so much from this place, and it's all come in very handy. Looking forward to...
I think you're right, but we're just going to run the HDD in parrallel from the power supply. Im pretty sure a PC HDD pulls more current than a...
Hey all! Thanks for all the feedback, I've been off the net for a few days so I've been somewhat unresponsive. I'll let you all know how I...
Yah, we'll just have it floating around sort of thing, hehehe.
Hi all, I have a laptop which the HDD has just died. The laptop doesn't need to be extremely portable so I've decided to put a normal HDD on...
Shrug, Im under the impression inductance slows current down. I don't really wanna buy an adapter, because I need one to handle 2amps and just...
Hi guys, It's been a while I know. I've only just modded something for the irst time in AGEEESSS. (Can't afford this hobby) I've taken a...
how funny would it be if there was a simple solution Like a belt hole maker or something *shrug*
If your soldering anywhere near transistors or PCBs, you want something like 15 to 25watts... Butane does sound cool, but you can't leave em on...
I dare say those temps are impossible for me this time of year. Looking at my desktop readout. My room temp is 27.9.. Outside my window is...
A couple of years ago a guy did it. He made a lan box with an lcd stuck onto the side of the computer. He just put the whole unit up on the...
I'd just like to remind you. The whole point of the heatsink is to prevent the little gray thing underneath it getting too hot. If you're...
Someone send me a dead cpu and I'd be happy to test this one for you.... If a .22 doesn't work, I'll get the .222 magnum. If THAT doesn't work...
Wow, my room runs at over 30 degrees most days. I got a Coolermaster HSF, somewhat bigger and better looking than the one I was using. I've...
Unfortunately I've tried that. I've tried it in diff computers. Definately wasted the card =(
Well, My graphics adapter was overheating during full on gaming sessions so I decided to fit on a blue orb. I put it in the freezer for...
How do I go about checking the validity of the sensor?
Yah, it's too high. The computer crashes as I mentioned. I don't understand why th ough why stock config. I put a thin layer of that stuff...
Around 8-10 degrees less. Problem is, if I turn off my case fans and run like a normal machine I crash while playing 3d games. That's not...
