I tried an external card. The screen remains dark but now the top half flickers sporadically.
I tried my friends PSU with an 8-pin ATX connector. No luck: pp_led3 is lit - no output to screen. Should I go ahead and RMA this board?
As far as I can tell No. I've tried both HDMI and VGA w/o luck. However, following a troubleshooting guide online, I unplugged all the ram...
Following the advice on this thread. I got a new Jetway MOBO and plugged two different power supplies into it, but nothing appears on the screen...
$43
Oh it works great, but not with iTunes of course. Some time after I posted, Mr. No-Speaka-da-english some how did a reverse lookup of my phone...
One more thing: It won't be any kind of "centre". Americans don't use your dyslexic spelling.
It will be both. I use vlc to play videos on linux, so I don't need all the codecs.
echo echo echo
Have you tried using an ubuntu live-cd to resize your partition? Ubuntu's partition editor should be able to move the unmovable clusters of your...
If you have two sticks of unmatched ram. The MOBO should run both at the lowest speed. For example, I have a laptop with a 512MB 555MHZ stick and...
I want some data redunancy so I'm going to take parts out of my old media center PC that's sitting in the basement and turn it into a RAID 5...
I have several WD external terabyte drives. They all spin down after like 10 minutes.
I said 8378 MB not 8378 MiB. Learn the difference
I emailed the seller and got this response: :duh:
I don't follow you. 8378122752 bytes / (1024^3) = 7.8 GiB
[IMG] [IMG]
So I picked up a cheap iPod shuffle on ebay hoping to resell it for more on amazon. It was marked "APPLE SHUFFLE 2GB - 2nd Generation" , came in...
[IMG] I wrote a script to read two images and concatenate them together at the right dimensions so each monitor has its on wallpaper.
They have a combined resolution of 3140x1050. The vram on a card is primarily for gaming and most games blank out the second monitor when running....
