I havent been around much lately, so i just found this threat and was amazed. Congratulations! I've had this idea of combining a big passive heat...
Wow, what an honor to be amongst the best mods of the year! Whoever wins, deserves it.
Thank you so much for the nomination! :clap:
thank you guys! :) you find some pics further up on this page. I put a heatsink on them. ;) I took a few more pics of the two siblings. [img]...
thanks! :) Alright im pretty much done with this project. There are still a few little things to do, like delidding the CPU, maybe painting the...
Thank you guys! :grin: @Cheapskate: I did another test today as you can see further down this post. Changing to thermal paste wont significantly...
Your build is looking really good so far! I like small cases. Its just a lot more challenging to fit everyhing inside! Im glad, that my work is...
@ cobalt: thanks! I will repeat that test with the side panels installed. that should result in improved temperatures. if not, i can still think...
:grin: [img] [img] [img]
I did a worst-worst-case test today. I ran Furmark for one whole hour. The config was as you can see in that last pic. The fans were running, but...
thanks! :blush: i did a few more little updates on the graphics card cooler and then i started to assemble the whole thing. [img] i made a...
Update for the graphics card. Tomorrow i still need to make a mount to increase pressure on the rear end of the graphics card and then i can...
Im not sure, if it that really matters. But its something i wont be able to change anyways. I started work on that PSU. First, disassembly: [IMG]...
Its about bedtime, so just some quick answers. Pprime95 has been running for about an hour and tmax is about 75-77°C for a short period. Most of...
Well it is 7700K, which all seem to run pretty hot. But nontheless im not really pleased with the temps. I did use some thermal paste on all the...
Thanks, ill get that done soon. I think it looks closer than it actually is. It should be fine ;) Yesterday i got a few smaller things done...
thanks guys! @Pliqu3011: those are really good ideas! S.H.H. would have been awesome, but i had to decide two weeks ago when signing up for the...
yes me neither ;) I hope to get that done and install at least the mainboard this weekend. Today i cut a few sections out of the clamping plate,...
got the clamping plate milled. Still need to cut out a few sections and drill holes in it and tap threats in the heatsink. [img] in the end, it...
yes i do :) i wanted to get that milled today, but that didnt happen. So i hope to get it done within the next few days. btw. just in case, you...
