Looks pretty normal to me. In the second pic, you can see where the load is applied, the temperature shoots up, the PWM detects and responds,...
I have a set of TP-Link 500mbps pass -through adapters and they have been solid for 3 years. Waaaaay better than any wireless network equipment...
How long roughly does it take for the machine to freeze? It does sound a lot like a graphics card issue. When a CPU overheats and the system...
Have you tried resetting the BIOS? Depending on your motherboard, there should be a button or a jumper normally consisting of two or three pins....
It's possibly a driver issue. Or maybe even your monitors firmware. I remember years ago I got an HD 7800GT that for at least two years worth in...
Do you repair/test/data recovery from anyone else's machines? I often use old reliable equipment to make test bench machines, rather than...
Hi folks hope you're all having a top day, I've just upgraded to Windows 10 and got everything installed - lovely. However, I've noticed in...
I've figured it out. Thought I'd post back to let you know I'd figured it out. See that TMPIN2 temperature of 55c I posted earlier? Figured out...
mrbungle - I have managed to downgrade my BIOS from the really naff EFI release they did recently which had next to no oc'ing controls - old...
Qazax - the CPU tops out at 65C, indivual cores are 65, 65, 62, 61. The sensor readings for the mobo are TMPIN0 29 , TMPIN1 25 and TMPIN2 55....
Thanks for the reply Pookie. I have Speedstep disable in the bios, still doing it.
Since I've had my current system just over 2 years now and games are starting to struggle a bit on it, I thought before I go dump a load of cash...
Thanks for your reply jinq-sea. I figured it out in the wee hours of this morning. I had been building the pc on my desk (not with the TV...
Hi all, I have built a pc intended for HTPC use. I built it using Windows 8.1, an MSI H87I motherbaord and a i5-4570 which has the HD4600 gpu....
Excellent! Thanks guys! I just wanted to check before I committed to my purchase.
Hello ladies and gents. Hope you're having a lovely evening. I've recently moved my PC to another room in my house and the wireless networks...
Cheers Rich, I thought so. My laptop will run without the battery in place, so when the mains adapter is plugged in it must bypass the battery...
Thanks CrapBag! (lol I like your name! :D) I found one on Amazon.
Sup guys :) I am trying to find a new laptop charger. I have found plenty on ebay that have the correct plug and voltage and have the model...
Rich - yeah I have tried everything in the KB article and ran sfc, still hasn't fixed it. I'm pretty certain I've done everything I can. Addie...
