90% of the time you may be an ordinary Joe, but put a hack saw, file and block of aluminium in your hands and you are elite in your capabilities,...
Agreed, especially given the parallels being drawn between bodybuilding and OC’ing. Bodybuilding is a sport of aesthetics not brute strength,...
Agreed, if modders are going to be involved in the design of cases then it has to be done in a more intelligent way: 1- On a complete new product...
Long before I knew of how Attila built his cases or bit-tech I was familiar with his case Cygnus X1, to this day it remains my all time favorite...
Just for future reference, be extremely careful when buying such cables, why? There's a defined standard for the component end of power cables,...
Criticism where criticism is due, but unfortunately this comment doesn't demonstrate the reality of the configuration. Yes the memory upgrade is...
I'm left a little disappointed unfortunately; disappointed that none of the sites I was checking out computex updates on featured this absolutely...
I haven't seen the corsair grommets in Australia unfortunately, you might want to give them an email directly to see whether they can send you a...
Depends on the mod, generally though I prefer proper cable grommets. The grommets available at these two sites will take care of most of your...
Sure gaming at the native res is going to be a challenge, especially for the latest and greatest titles. However there is an advantage to higher...
Nice over reaction, only it was Steve Jobs himself that said that apple would never produce a netbook. All technology is interrelated, and it's...
It's just enough headroom for a doubling, but i'd suspect that there would also be a market for 300dpi screens in professional industries. Then...
The basic concept of a netbook had nothing to do with apple, they originated from the OLPC [One Laptop per Child] initiative to provide low cost...
http://www.mnpctech.com/CarbonFiber_Gunmetal_Titanium.html This is the manufacturers webpage, shouldn't be too hard to find a company close by...
What pins are you specifically after - 24/8/6pin, Sata, 4pin peripheral, fan, usb/front header? mdpc sell genuine molex mini-fit Jr [aka 24/8/6...
If you want custom cables there's no doubt that making them you're self is the best option, and all the parts required for a build are readily...
Jamie i've found Chilledpc to be excellent, their high density sleeve is of a comparable quality to mdpc sleeve. The heatshrink on the other hand...
I highly doubt that's the problem, cathodes don't draw much power and you'd be more likely to see system instability if a particular rail was...
I highly recommend a specific tool, not because it makes the job any easier but rather they help to ensure you don't damage the prongs on the pins...
100% agree with what Picarro posted, but i'll just add another layer to it. Modding is as much about 'learning' as it is the physical...
