Below is a budget PC that I have put together according to the best of my knowledge. I am based in Germany so these are euro prices. Intel E5200...
Been a while since I've been here. Last I remember I was modding a PC in 2005 and posting some pictures of it. Well, that old, rusty vessel is...
Thanks for the replies. I know this isnt totally mind blowing next generation creative. This is my second mod, and my first paintjob of anything...
go wild man. good luck with this!
"Caution!" A Keyboard mod. I would appreciate any comments, positive or negative. Thanks for looking. Log:...
Yay done. This update has taken a while, because spray paint takes 2 days to cure before you can sand it, so after each coat I had to wait and...
Log Discussion Here it is, my good old keyboard. Nothing wrong with it really, except that it is black and boring. Time for an upgrade. [IMG]...
I built an acrylic case from scratch and did it only with a jig saw. Needless to say it was a real bitch to polish, but if you have the time you...
I am pretty sure he is talking about the one that was made for INTEL for the CBIT like 2 years ago.
this makes me so jealous!
I recently moved across the Atlantic (to Europe), and am now in need of a new TV. Sadly in this area i have little to no knowledge and usually...
When i evaluate the impact of these next gen consoles, i just think about the time the ps2 and the xbox were released. I remember them advertising...
Haha ok i did a really stupid mistake with it. I knew there were different SATA connectors on my mobo, but i didnt know there were 2 on the drive...
I did a case mod recently which forced me to remove all of my components and leave them disconnected for about three weeks. After finishing my...
I posted this a coupe of days ago in the modding forum, but nobody there seemed to know. Since the deadline for my project is in two days, i need...
i did another mod to my main post.
I have one SPST switch, and two circuits each with 4 LEDs on it. I want all 8 LEDs to go on with the throw of one switch. Can i take two circuits...
I am reviving this thread because i made a pretty big edit in my top post. Thank you for your help
hmm i heard that yellow is 12 volt, red is 5 volt and black is ground. I will use 4 LEDs in a series, each LED is 3.3 volts, so i wont need a...
It depends on what "plexi" you use. "plexi" is a specific brand of acrylic. High quality acrylic can take quite a punch, plexi would be one of...
