you could place the calendar as an ical file on the web server and link to the calendar using a url or you could google calendars, install the...
quick and easy way to share the calenders would be to create a calendar on one machine in a shared place as a .ical file. Such as a NAS or a...
Great work, colour are great, you have now just inspired me to mod my p180. keep up the good work.
looking good, liking the paint work and the side vents keep up the good work. Subscribed!
Maplin sell some of power connectors especially molex and motherboard not so sure about Sata and PCI-e though
have to agree ive noticed since using ff3 that my system is more resposive when multitasking, with multiple tabs open in ff3, when compared to ff2
oh i might have to get me one of these soon, dualshock 3 should have been included with the ps3 from the start.
if I remember correctly from when I had a 360 you could set the VGA resolution in the display setting to a wide-screen resolution. which would...
I think it would be a good idea, especially for those people who have non backward compatible ps3s disc wise, although if your ps3 can play psx...
There are suppost to be quite a few GPUs being released in the next month or so, from both nvidia and ati so i would say wait and see whats what...
I have been waiting for in the in game xmb, and the other extra features included in this firmware for far to long, and now the wait is almost over.
Cosmos-Skulltrail by Coolmiester gets my vote the side panels look great:thumb:
The Tuniq Tower and Artic Freezer Pro 7 are both good CPU coolers not sure bout Thermalright Ultra-120 as have has no experience with that cooler.
OEM is original equipment manufacturer and considering you are manufacturing the pc you can use an OEM copy of windows, I think. I have installed...
Infinity Ward make better COD games in my opinion, but i was hoping that COD 5 would have kept the modern feel of COD 4 I think WW2 may be a step...
I had a problem like this with my monitor i changed to the second output on my graphics card, and that fixed it, for some strange reason the...
nice looking case, has potential. shame ill probably never be able to afford one
Personaly FF3 due to the amount of customization you can do with extensions etc.
