I was meaning how to change the account. A VPN/Proxy doesn't help me if I'm already in the US. Using a UK account with an American IP still gives...
I personally have never done it. In the past I've had issues adding Physical games to Steam. I think it was Hawx that started it for me. Then...
I recently moved to the USA for University. Now I'm not entirely sure how Steam/Publisher works the prices between the countries but I have...
I am looking to upgrade the system I currently own. My Desktop is now 3 years old and running a Phenom II x4 955 @ stock 3.2 GHz and a stock ATI...
The Current Budget max is around 300. But that could be stretched if I waited another week or two till I buy it, and I was going to buy it after...
I am in a long process of PC overhaul. I don't have enough money to spend in one go but when I build my PC I was faced with a choice of: - great...
http://www.scan.co.uk/products/2gb-hypertec-ddr2-pc2-6400-%28800%29-240-pins-non-ecc-unbuffered-cas-6 Would this work. The manual says it has...
What about UV LED's and an appropriate reactive coolant?
Basicly with my use cases in mind is an ultrabook worth the money or should I get a high end netbook or low end small light laptop? Sent from...
The coding is just run of the mill C and java at the moment. Storage space isn't an issue as I have a large laptop at home from a few years ago. A...
I am currently a student and my laptop is rather i'll suited to be taken into uni for work purposes as it is a heavy 17" beast with a failing...
Unfortunately I didn't really expect it to work and it didn't.
I have been playing this game for a few hours and everything seemed fine then while playing the tanker hijacking mission everything crashes....
Just checking. Thanks for the tips.
So just to clarify, for the same power rating you get higher speeds. But if the temps are higher wont that make the fan use more power (motors...
Sorry if this has been asked many times but I don't have time to trawl forums. I am currently thinking about building a new PC. The funds are...
Never mind, binary domain doesn't work period. The demo has been exceedngly poorly ported from the xbox, and as a result I dont think it will work...
I was wanting to play the demo and cant (otherwise i wouldn't be here) The configuration app which comes with it doesnt recognise the dedicated...
Can anyone tell me what game this footage has come from. it is a game based on the Alien franchise and that is all I know....
Not just steam games I was referring to all my games and programs that the product key is no longer valid.
