Amazing work! Love it !! Congratulations
My PCB for LCD2USB: [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] Lb_xlZWlEJk
Hello! Anyone used all the GPOs ? I uploaded the original firmware (usblcdconfig.hex) and i can use the pin #2 #4 #5 #6 #7 of the PIC, but the pin...
OMFG!! :jawdrop: :jawdrop:
Amazing! :):clap:
Now in a PC Case: [IMG] [IMG] [IMG] [IMG] [IMG] Video: gon4R5OdoNc
:thumb: :thumb: Nice!! Thank you
Hello! Thanks :thumb: i have put the final video on my webpage (in portuguese): Link The video:...
I need only to solder some wires and put everything in the box that I made of acrylic (to a pc bay 5.25). To recap: When you start it...
Update: Some photos, just to show the current appearance of the main box: [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] :) the...
Well, I have a circuit in one PC (that is connected 24 hours) to turn On/Off the fans, it consists of a program in VB that active the pins on the...
:jawdrop: :jawdrop: Great Great Job! Congratulations
Can we use the lcdproc software with this Usb-LCD circuit?
Final Video: http://www.viddler.com/explore/almamater/videos/1/
Hardware.. Asus M4A78-HTPC AMD 780G SKAM2/AM3 AMD PHENOM II X4 955 BE Quad-Core 64Bits 8MB BOX SKAM3 G.Skill DDR2 2x2GB PC8500 CAS5 PK OCZ...
:jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop:
Hi again, I mounted a AMD2600+ just to see how it is ..: [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] This here is a light sensor... I put two blue...
:) Yes, lot of them.. the purpose it is for turn On or OFF every Fans..Leds..etc. immediately General explanation: [IMG]
Tchan Ran... the iMon arrived to my hands (with some difficult): [IMG] [IMG] [IMG] Done the perforated plate: [IMG] [IMG] Lot of wires to get...
I cut the side lacked to put the acrylic behind: [IMG] [IMG] [IMG] The perforated plate to put in front of the 250mm Fan: [IMG] The...
