[img] [img] :D
So, more detail later but the TL;DR version is that I found myself with some very small living arrangements and got creative. Decided to see how...
Fixed, Thank you.
So I have a lot of time on my hands for the time being and I wanted to do something productive. These are a couple how-to videos that I have done...
Just a another photo to show the "action" shot on my messy desk: [IMG] And this one shows no visible wires!! (Sorry for the crappy photo,...
Yeah it helped a ton!. The only wobble I get now is slight and it is from the desk it self. I think all in all I spent maybe just over $100....
Figure I would resurect this and just show a few "fixes" that I have done. Basically the whole stand has been working flawlessly with one down...
I will be painting it flat black like the stand. Also I realized something else while trying to make it so that I can adjust the height, I fail...
And she's done.... sorta... Upon putting on the monitors I found that I messed up some where and the right and left monitors aren't in line with...
I have seen that autozone now has some touch sensitive switches now as well.
I have that same one. The only downside is that if you are not on same powergrid that is in Japan (100Vac 50hz I believe) then it will run hotter...
And now to show the monitor mounts part one! [IMG] [IMG] [IMG] Part two will be the two mounts for the right and left monitors. The center...
Yeah I am aware of that. That is why when I put in the correct bolts with the nylon washers and such, I stood on it. :) Again, I am aware...
I did. And no worries, I know it doesn't look great but it really is strong. And the most weight that will be on either arm is no more than 10 lbs...
Here is my custom triple monitor arm that is in the works. What I am still trying to work out is how I should fabricate the mounts for the...
Just out of curiosity, was there an ATI card mixed in with all the other NVIDIA cards in the picture on the 8th(?) page?
Erm ... Bring"ing" maybe? :P
They already have this one out. I know that this is real because I have seen it for sale at the local GameStop where I bought my Wii...
I think that my main grip in it is the features that NVIDIA cannot put into the vista drivers because of the way vista was built. Specifically...
Basically you would have to get the service member to purchase it for you. In order to purchase it yourself, you would need to have a military ID...
