Great project and final result! I voted for this for mod of the month. However, I hope the paint provides some thermal insulation, because PLA is...
[IMG] The system is complete. Everything is up to date, did some overclocking and some stress testing. It is now delivered to the owner, who has...
And the second timelapse video is ready [MEDIA] Because it will be a few days until I upload the photos and video of the finished build, I put a...
Τhere has been a lot of progress on the build, so it's time for an update! I 3d printed the final cable cover for the cables on the right of the...
Quick and short update. I made a simple timelapse video working on the system. [MEDIA] I will make one more at least with the new hardware and...
[IMG] Greetings from Greece. After a long break of about 3 years I return to modding and I am starting with project "Necromancer". It is a system...
Thank you for your responce and quick solution. I am glad there is no more confusion about the build. Great builds this month and good luck to...
Um, I don't know where I should mention this, but the thumbnail picture for "Caelum by TheXviper" is a picture from another build! I am talking...
This turned out amazing! Attention to the color theme, nice clean lines, some unusual things done (I mean that in a good way), balanced...
I voted for one, but I wish I had also voted for the wood and copper one. Great builds!
Can you share with us the weight for one of the parts? 3D Hubs and Shapeways use size (volume) to calculate costs, but 3D printer owners can...
What material are you using? ABS or PLA? PLA is easier to print in general and does not shrink as much as ABS does. I used PLA for my project. I...
There is a modding solution that would work for that. Deepen the spot the second rotary fitting screws so that it is further "inside" the acrylic.
I understand what you mean. I agree that you barely notice them. If they were silver and blue capacitors like the HOF cards then it would be quite...
I like it a lot! It looks like a build of a friend of mine. I helped him by designing and 3D printing the covers for the PSU and motherboard IO. I...
Really nice colors man! Great paracord sleeving too! Could you cut circle stickers to cover the 6 visible capacitors of the GPU with light blue?
You can ask Bitspower directly I think. They are awesome people there! If there is no arrow near the ports and nothing in the documentation, I...
It does look great indeed and there seems to be plenty of space. I hope things go smoothly from now on for your build.
Should be better. Will the fittings on the block fit there? Think of the tubing run also near the radiator and the GPU! Are you using 90 degree...
That is a very nice acrylic piece! Interesting build, keep it up! What red fans are those? NZXT painted red?
