Dude! I'm gunna do this in UV marker on a normal closet door so it glows under blacklight! Wee for me!
If it is live ammo, I'd wire it up so they go off if somone messes with your case. Halgy
A peltier is all that most little mini-fridges have. To cool of the whole container, I'd mount either a big ol' heatsink or just a piece of steel...
Americans by and large are too lazy to use manual transmitions (myself included). And, by and large, automatics work just fine if you are used to...
This will be sweet, but I hope they don't bog it down too much with graphics. I still prefur RA2 over Generals. PEACE
I actually thought it was just part of the episode. I thought it was funny. But in any case, I don't blame Comedy Central from censoring the...
Small update here. I finally got a chance to get to the Home Depot and get some cutting disks so I could finish up. [IMG] I pretty much...
Ok, kool. Sorry if I seemed like an a**. You now have me thinking of doing a combination lock for my mod. Locks rule. DHDs rule harder. PEACE
Oh, he is just gunna use all 9 chevron points. I thought his code would be like an address for a planet. My bad. PEACE
I don't know if you have a reason for a 9 digit code, but the Stargate has the 7 coordinates and the activator, 8 digits not 9. PEACE
In that eventuality I'll have a place to keep my coffee warm. :D But if all else fails, I may get a bigger Peltier cooler or try to watercool...
Now to start with the side. First, tape it up real nice. [IMG] Then, tape a bit of paper to it, cutting out the design and tracing with a...
Project: Amp Feedback Thread What do you think? Any questions, comments, sugestions, or flat out insults will be much appreciated. PEACE
The Journey Begins Right, so to make an AMP computer, you start with an junky, old Gateway computer case from the closet. [IMG] Then, hack a...
Many moons ago, a computer mod was conceived, the greatness of which rivaled that of something utterly mediocre. Alas, said project, dubbed lamely...
Righto. Thanks guys. Hopefully I will get to the point that I actually can paint my case within the next year. PEACE
This is just like any other release of GTA. San Andreas and Vice City both came out only on the PS2, but after a suitably long time so the...
What is some good paint to use for steel and plastic computer cases? I've used Krylon (sp?) Fusion in the past for painting the front of CD-ROMs,...
Thanks a bunch.
