But will it run crysis?
New model sent to Jez [img] Corsair - CX430 by Tom Cornick, on Flickr No internals, but the externals are accurate and labels are all high...
I'm not sure if this is what you mean, but I made a model of a standard ATX I/O panel. http://scc.jezmckean.com/item/483 if you already have...
I've got some motherboard components on the way. [img] Intel - LGA 775 by Tom Cornick, on Flickr [img] LGA775 Socket by Tom Cornick, on...
6970 has just been added to the site
yeah, but ive had problems with my uploads so it may not have sent.
I dont think Jez got my email so here is the file link. http://www.mediafire.com/?piohjkd5ovkvt1r
Hi LooseNeutral, Sent to Jez for uploading [IMG]
I have emailed and posted my entry
My stage 1 design It can take a 3.120 radiator in the roof, base or front and upto two psu's. 10 5.25" bays in the front with removable hard...
Ive finally got some time to work on my design, and got down to the museum for some ideas. Check out the cable management [IMG] The case is...
Bit of a boring model, but I thought it may be usefull. [IMG] Blank motherboard backplate submitted to SCC
I started this model with a tape measure and ruler, then got a digital vernier. Ended up remodelling earlier parts more accurately, and in half...
Your socket models are awesome though, I started one and promptly gave up. Thanks Ron-ski. To be honest its a very easy case to draw, as...
My model is FINALY complete! Silverstone TJ07, accurate to 1mm. Hope this helps everyone with their modding, please let me know if you create...
Sketchup 8 looks very nice. The solid parts tool is lincluded in the free version, but it doesnt give you the full set of features. From what...
I would appreciate an extra month. I could be done tonight but its not to a standard im happy with. Gives me some time to post previews pics too.
I have a motherboard model coming soon which is pretty accurate. The positioning of the slots should be accurate to 1mm. Im hoping to model an...
