As a smoker, I can't imagine why anyone would really want to smoke inside a house... It does get freakin disgusting.
I'm really considering one of those... little strapped for money right now though
I wish I had those skills... mine would come out completely different :grr:
Buy the silver, and paint it black, it should be light enough in color that you don't even really have to worry about priming... then put the...
well, it depends on the look you want... would you like to have two "borders" to the frosted plate... such as putting like a cathode on the left,...
Delete you?! Its not worth it man!!! Don't do it, theres always things to look foward to, its never as bad as it seems. You can find help,...
Hey, nice case, but why didn't you wire the pump strait into your powersupply? Instead of having that gay cord come out, it would like 10X better.
Something like that would be hard to take a picture of, try to take a much closer picture, I can see what your talking about, how now instead of...
Holy Sh**, that is really nice, probably one of the best non-cutting mods i've ever seen, seems so simple, yet changes the look of it completely....
cool, how would you go about doing that?
So how did this turn out anyway? No fallow up? No one figured it out? Well i wanna know!!! Someone can figure this out...
Pretty sure that he'll be fine, considering people wrap up their ide cables. Thats how rounded ide cables started. And in the future, you...
So why the hell would someone waste there money on such expensive equiptment, just to get such a small increase in performance, Intel should just...
What are you cooling with a 72 watt peltier? If its your processor then I would deff. recommend a 226watt peltier, and if its your video card i...
Be careful you don't get any whirl pools going, cause it might start to put air into your tubes, meaning your watercooling system, meaning bad for...
Wow, you have the same VCR I have, hmmm mine just went bad two days ago actually, it won't go on, no power or anything, just won't work when i...
Well it has a lot of amp's to the 12 volt rail, you could probably use this as a psu for a peltier, so long as not many things are also running on...
ENOUGH SPAM
How far into the cd drives does that radiator, plus the fans go into the cd drives, I know that the way you have it, its not interfearing with...
I think that it looks pretty good, but a high deffinition picture would deff. work better :thumb:
