Peripherals £100 racing wheel
Discussion in 'Hardware' started by pyro1son, 3 Jun 2011.
  1. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    Can people please recommend me a racing wheel for pc at about £100!
    Thanks guys!
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    only one worth getting for that price is the Logitech Driving Force GT
  3. bagman
    bagman Minimodder
    18 Apr 2009
    there is also the Saitek R660GT which is meant to be good
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    second hand g25? i believe they go on fleabay for about £120
  5. pyro1son
    18 Aug 2010
    I've been looking at driving force gt and it looks like my best bet! Thsnks
  6. Strudul
    Strudul ~
    31 May 2010
    For £100 a dfgt or the F430
    A second hand G25 is about £160 on ebay :/
    Or I would recommend stretching to a G27. I got mine for £181 by using discounts and cashback.
  7. Sexton
    Sexton Minimodder
    2 Jun 2010
    +1 on that. Best wheel for the price... had mine now for nearly 2 years and it's still amazing :)
  8. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    Hands down Logitech G25 or G27 is the wheel to get if you are into racing games. My god... I am not lucky enough to afford one - A am kicking myself about letting a £90 deal on Play go when they were just about to stop production. I know two people who have them and I couldn't use another wheel again. It is perfect.
  9. Zehetmayr
    Zehetmayr Minimodder
    23 Apr 2011
    Can't go wrong with the DFGT for the price. Probably have to double your budget for anything much better. Use it with the ps3 too so handy for a session on grand turismo :)
  10. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    If its for EA games the Logitech ones have generally better support.
  11. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Under £100? Logitech DFGT hands down.
  12. mystvearn
    mystvearn any-may
    12 Feb 2009
    I've used both G25 and DFGT. FFB DFGT better-newer gear FFB mechanism-despite only one motor. No clutch. Id you have no idea how much sim racing you will be doing, then best thing is to start with a DFGT and progress higher. I am currently using DFGT with DPS-200 paddle shifters
