Displays £150 display
Discussion in 'Hardware' started by sharpethunder, 26 May 2012.
  1. sharpethunder
    sharpethunder What's a Dremel?
    25 Mar 2010
    any one got a few ideas for a display for a £150 its for my brother
  2. Nazata
    Nazata What's a Dremel?
    2 Sep 2011
    You should read this if you want to be clued in in regards monitors: http://forums.bit-tech.net/showthread.php?t=218867
    This is a reasonable one for under that price.
    Goodbytes is generally the go-to guy when it comes to monitors around here, he'll more than likely have a suggestion by the end of the day...
  3. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
  4. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    I was about to recommend the LG IPS panels but I see I've been beaten to it, twice. Love mine, wish I could afford another two!
  5. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    I just bought the 23" if this for £160. But the 22" is in budget. Up to you...
    Clicky
