Displays £150 Monitor suggestions
Discussion in 'Hardware' started by Sponge12349, 23 Mar 2011.
  1. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    So I need a new monitor preferably 1920x1080.
    Buget: £150.
    Uses: Gaming and video editing.
    IPS monitors seem too expensive and i think LED backlight is a bad choice. :confused:
    Thanks
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    BenQ G2420HD, if you can, it's the 24" bigger brother to my G2220HD (21.5")
    1080P native, will take VGA/DVI input.
    There may be better out there, but the G2220 is one of the best screens I've used. (Not saying much, my previous screen was a Samsung Syncmaster 170MB, manufactured 1999)
    I'm sure someone will find some Dell monitor made from spare Chuck Norris parts that fits your budget, but I can offer the BenQ as an alternative. Also the G2420 goes for a few pence over 150 on Scan.co.uk (£150.29 at time of posting)
    All in all: It's a reliable, effective screen that should fit your needs, it might not have the "Wow!" factor of high-end IPS panel, but it's cheap, effective, and reliable.
    Sponge12349 likes this.
  3. GoodBytes
    20 Jan 2007
    Check out the LG IPS-236V-PN LED
    It is an LED back light, glossy frame (not the screen), and non adjustable stand (other than tilt) BUT it is an IPS panel, at an affordable price.
    Alternatively, a bit more expensive (check eRetailers for better prices than Dell U.K)) the Dell U2311H, full matte, fully adjustable and solid stand. Still IPS panel, high grade CFL back light.
    Another choice, cheaper, better back light spreading (still IPS and high grade CFL back light, same stand), and a bit better out of the box box (all points compared to the U2311H), the Dell 2209WA. But it's 22inch and low resolution.
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  5. Sponge12349
    12 Apr 2010
    Thanks for the suggestions guys, +Rep for all. :)
    The LG IPS236V-PN would be the best choice but is out of stock everywhere. :wallbash: The G2420HD looks like the best option so far so I should pick one up by next week unless anything else crops up.
    Thanks for the help! :thumb:
  6. sb1991
    sb1991 What's a Dremel?
    31 May 2010
    I don't think the OP has access to the marketplace, so it seems worth reposting this here:
  7. GoodBytes
    20 Jan 2007
    The best option is to wait, and get the LG one.
    I laugh to so hard when I saw the BenQ G2420HD official product page. They have nothing to say about it, so they say that 16:9 displays are better than 16:10, while it's the reverse. Also they add on how 16:10 distorted images... riiight.
  8. Sponge12349
    12 Apr 2010
    Okay so U2311H at that price is an absolute bargin!
    However, I'm lost as to how I get the cashback thing. If I click on the link through quidco do i just search for the U2311H and add to basket?
  9. Sponge12349
    12 Apr 2010
    I think i have it almost... :s
    Right if i buy it through Small buisness i can get 10% Cashback and 5% off. But I still have to pay £16.80 postage
  10. Sponge12349
    12 Apr 2010
    I have no idea how I get the cashback but the order is done :rock: :D
  11. GoodBytes
    20 Jan 2007
    Sorry can't help you there. I never checked U.K online stores.
    But please, come back with your reaction once you get it.
    Your opinion is important for me to know, in better helping others.
  12. Sponge12349
    12 Apr 2010
    Sure! Would be happy to help :)
