Build Advice £200 Challenge
Discussion in 'Hardware' started by outrider2142, 29 Oct 2009.
  1. outrider2142
    outrider2142 What's a Dremel?
    29 Oct 2009
    Hi All,
    I am trying to upgrade an existing system. Please see the following:
    Requirements
    Mandatory:
    1. To play the following games at the highest details, 30+ fps, and at 1280x1024:
    Call of Duty Modern Warfare 2
    Battlefield Bad Company 2
    2. The motherboard should have 2x16 PCIe lanes for either crossfire or sli
    Optional:
    1. The system should be capable of a future upgrade path
    Parts Needed
    The only parts required for the upgrade are:
    1. Motherboard
    2. CPU
    3. RAM
    4. Graphics Card
    Budget
    I only have £200 to spend on the above parts.
    Any advice would be much appreciated. Thanks in advance.
    Cheers
  2. Andersen1337
    Andersen1337 What's a Dremel?
    10 Apr 2009
    That budget will just about cover motherboard and ram...
  3. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    So that £200 is for which of those 4 items?
  4. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    unless you want to try ebay or go rumaging through skips you wont get those 4 components for 200 quid. not if they are meant to have an upgrade path anyway.
    I can maybe think of 1 set, get a am3 sempron, dirt-cheap am3 motherboard, some dirt cheap ddr3, and a cheapass gfx card. being as these will cost 50 quid each you dont get much for your money. the MB will not have crossfire, the cpu will not be very fast, you wont get much ram, and the gfx card wont play those games at a high level of quality.
  5. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    Thats hard if not impossible.:eyebrow: The best for those "mandatory" requirements would be:
    CPU: Phenom II X3 720 BE £97.00
    Motherboard: Asus M4A79XTD EVO £82.77
    RAM: 2x 2GB Corsair DDR3 (1333) £69.24 (for both sets)
    Graphic s Card: 1GB Sapphire HD 4890 Vapor-X £161.22
    Total: £410.33
    Conclusion: You need about double the money for what you are looking for
    Rotcrack
    PS: How long have you been building computers?
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Due to the roof splintering price rise of memory recently then £200 simply isn't enough for a DDR2 or DDR3 system that can play games , extended to £300 should manage some lightish gaming...
    CPU - AMD Phenom II X2 545 (BE isn't necessary and it'll save you £10 to go with this one)
    GPU - XFX 512MB 4870 (though If you can get a 1GB version)
    RAM - Anything you can find really for a decent prices (4GB minimum) but for the sake of consistency this kit is from scan - Corsair XMS3 4GB 1600MHz CAS 9-9-9-24
    Motherboard: MSI 770-C45 (scored well with bit-tech, and cheap)
  7. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    It should run it, but it'll struggle if I'm honest...
    Just a note, Bad Company 2 doesn't have released running specs yet, so I'd wait until it does before buying anything at all... maybe by then you'll have enough money to get a GOOD system
  8. outrider2142
    29 Oct 2009
    Thanks to everyone that's replied so far, so quickly, and so nicely. I have definitely come to the right forum.
    In fairness to everyone, I should have said that I would be trying to get all the needed parts from ebay. It's been years since I last built my own rig (see below, which is not the machine being upgraded), and I've only really understood and kept upto date with Intel/Nvidia progress since. Today, it sounds like the AMD/ATI combination, although not ultimately faster than Intel/Nvidia like-for-like, is a much better bang for each buck.
    Ideally it would be great if I could get a shopping list of parts, upto 2 years old, that I could use to hunt with on ebay. I'll be looking/hoping on ebay over the next 30 days. I suspect that most people's lists will mention AMD/ATI, and that's the area where I need the most help.
    Thanks again for all the input so far.
    Cheers
    evga 680i
    e6600@3.4GHz
    4GB Corsair XMS2 6400C4
    2x9800GTX SLI @ 1280x1024
  9. Rotcrack
    24 Jul 2009
    Ive already posted it but for the sake of making a strong argument I will post again :thumb:
    Rotcrack
  10. barndoor101
    25 Oct 2009
    gfx card seems a little OTT for what the OP wants
  11. doggeh
    doggeh What's a Dremel?
    27 Apr 2009
    Yeah a 4890 is well OTT for 1280x1024 gaming!
  12. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Yup but OTT = good when your budget is that low, it gives you headroom
  13. doggeh
    27 Apr 2009
    No... by definition OTT is excessive, therefore unnecessary, therefore bad when working to a budget
  14. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    By definition OTT is over the top, by definition headroom is extra room for growth and increase... you see where I am going here?
  15. doggeh
    27 Apr 2009
    Yes I see where you're going but you seem to misunderstand the term "budget". A 4890 would be 3/4 of that £200 budget in one go and therefore is not a helpful suggestion.
  16. bigsharn
    9 May 2008
    I stick with my suggestion of the 4650, maybe a 4830 if the budget allows (Or a 9600GT if you prefer NVidia)
    E7400 or E8400 are about your price range
    Look for any P35, P45 or X48 boards (there's a P35 MSI board, mint condition on tehre now for £50), they tend to be pretty reliable and better for overclocking than some other chipsets.
    Then pretty much any DDR2 RAM that'll work in the motherboard (most if not all motherboards will support 800MHz, some 1066MHz, just do some research on the board before you get it
