Equipment £200 to spend, what lens to buy? (Canon 450D DSLR)
Discussion in 'Photography, Art & Design' started by jezmck, 19 Nov 2009.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi Gang,
    it was my birthday on Tuesday and I got £200 from my gran, and would like to spend it on a new lens for my camera.
    I'm still relatively new to photography, so would appreciate your advice on what to get.
    (I currently have only the stock 18-55mm lens that came with the camera)
  2. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    It depends what you fancy doing. Are you more interested in focusing on one particular field of photography or do you want something that will be good for all around use.
    If you are just looking to expand your creative skill, I'd look into getting a 50mm of some sort. I've seen some very nice results from the Canon EF 50mm f1.8 II. The bokeh on that thing is gorgeous.
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    I think nature photography is my most likely subject, am surrounded by trees here, and near the New Forest and the coast. I have taken a number of shots hoping to crop them tightly to achieve a sort of zoom.
  4. Tim S
    Tim S OG
    8 Nov 2001
    Are you looking for a telephoto zoom lens then? 17-55 covers your wide angle fairly well, so I'd probably look at the EF-S 50-250 F/4-5.6 and if you can stretch to about £225, pick up an EF 50mm F/1.8 II as well.
  5. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    I can give a halfway nod to the 50-250 - I have one. Bokeh is HORRIBLE though so you have to really use that in your composition or learn how to work around it in photoshop. That being said, I've still not sold mine - it does the job I need it to and the IS and range are great for the price.
    Personally, if you're shooting "nature" that can mean two things - wildlife or landscapes. If it's landscape, look to just upgrade the lens you have - I shoot a good 90% of my shots at between 17-35mm. If you're looking at wildlife, you need the telephoto at times and low aperture at others, so tim's recommendation of both those lenses will be by FAR the best bang for your buck.
    Hope that helps. :)
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
  7. smc8788
    smc8788 Multimodder
    23 Apr 2009
  8. Tim S
    Tim S OG
    8 Nov 2001
    I tend to use onestop-digital.com since Canon lenses have international warranties. I won't buy a body from there though - I tend to buy them from a UK supplier with guaranteed UK stock.
  9. whisperwolf
    whisperwolf What's a Dremel?
    1 Sep 2004
    I use warehouse express for a lot of things, Karlu occasionally for some studio things and ffordes.com for second hand suff
  10. gavomatic57
    gavomatic57 Minimodder
    23 Apr 2009
    Sigma 70-300mm AP0 DG Macro...
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    That's very specific, I assume you have one yourself?
  12. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    Since you've got a Canon body, I'd advise putting the cash towards a Nikon one.... :p
    Kidding! My dSLR came with an 18-55 kit lens, and the first lens I bought was a prime (85mm) that's relatively fast (f1.8d); shooting with fast lenses is tremendous fun, and really allows you to be creative with depth-of-field, focus and composition. Fast lenses are often used for portraits, but they can also be great for detail shots (this, this and this) - just because you're surrounded by landscape doesn't mean you need to use a big telephoto to take pics.
    Just my 2c, anyway :)
  13. Cptn-Inafinus
    3 Mar 2007
    I own one of these and although its a very nice lens, I wouldn't recommend it as a first off lens. I wish I had gone for a nice 50mm lens before I had jumped into all of this telephoto business.
  14. theazz
    theazz What's a Dremel?
    21 Nov 2009
  15. jezmck
    jezmck Minimodder
    25 Sep 2003
    That's what I ended up getting!
    I paid a little more than that because I decided I didn't want to wait for delivery from an online shop.
