Build Advice £200 upgrade budget
Discussion in 'Hardware' started by MrP, 3 Oct 2013.
  1. MrP
    MrP seeking inspiration
    5 Jul 2007
    Thanks to some overtime, i have about £200 to spend on some new shiny bits for my system
    at the mo its the following
    Motherboard : MSI Z77A-GD55
    CPU : Intel Celeron Dual Core G530
    GPU : ATI 4870 512mb
    SSD : crucial 64gb
    PSU : Corsair hx620
    Ram : 8gb Kingston HyperX Genesis PC3-12800C9
    Its mostly playing WOW and trackmania at the mo, so it would probably suffice, but i really do fancy something a little better.
    If i had the chance, i would be buying a new CPU, GPU and SSD, but £200 defiantly stops that idea, so could anyone make any recommendations as to what would be worthwhile purchases within my budget, and the best order to do them
    is it worth buying a K series cpu second hand, or am i just wasting my money with what the machine does?
    cheers
  2. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    Try and buy 2nd hand core i3 and pair it with an HD 7870 then sell your old gear your current cpu,gpu,ssd and use the cash to buy a nice 256gb ssd...
  3. TheJDog
    TheJDog What's a Dremel?
    7 Sep 2013
    I agree on the 7850, they are a great card for the price, if you have a storage drive, a 120gb ssd will probably do you for the OS and your most used programs
  4. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    You can pick up a I5 2500k for around £100 now. Then pick up a 7850, job done.
  5. MrP
    5 Jul 2007
    As I have a £20 ocuk voucher, is it worth getting the 7850 new and going second hand on the CPU?
  6. AlienwareAndy
    7 Dec 2009
