Graphics £250 to spend on graphics... but which card?
Discussion in 'Hardware' started by somewhereoveryonda, 7 Jun 2010.
  1. somewhereoveryonda
    somewhereoveryonda You'll never know when to buy!
    6 May 2010
    Hey all,
    So far my build is as follows:
    i7 930 (Titan Fenrir cooler)
    p6x58d premium
    3 gigs of ddr3 at 1600 mhz
    1TB samsung F3
    850W HXUK Modular Corsair (I'm hoping on keeping this a while/going crossfire/sli eventually- thats why its huge!)
    Antec 902 case
    So the big question really is what would you spend £250 on if you were after a new graphics card?
    I have had thoughts on what to buy but dont want to sway peoples' opinions! Is there any advantages of buying ATI over nVidia or nVidia over ATI I should know about?
    Also which manufacturers would you recommend?
    Any help is appreciated!:thumb:
  2. The Toy
    The Toy The Ticking Time-Bomb
    26 Feb 2010
    For that budget and build I'd say a 5850 is a solid card for you.
  3. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    A HD 5850 would fit the price range... or a 5870 if you found some extra cash.
    Nvidia has Physx. Ati has the better cards in each bracket for the most recent generation.
  4. deadlyavenger
    deadlyavenger What's a Dremel?
    6 May 2010
    Yup - 5850 is probably the best bet for that budget, you could get an nVidia 465 though for that money I think?
  5. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    You could get a 465 but you'd be spending more money to get less. The 5850 is without doubt the best card.
  6. adidan
    25 Mar 2009
    5850, best performance and efficiency for the price.
    Also very low temps.
  7. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    The type of card is pretty obvious; a 5850. However which version of the card is a little more intresting. How about the Powercolor 5850 pcs+. Quiet aftermarket cooler and a slight factory overclock?
  8. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    sapphire HD5850 toxic? youll be getting close to HD5870 performance.
  9. memeroot
    memeroot aged and experianced
    31 Oct 2009
  10. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    True, I run a 295 and it's still top notch - beats the 5870. I wonder why that ebay item has a GTX 285 picture rather than a 295 picture ...
    For a new build I'd still be tempted to go the 5850 however. DX11 rather than DX10 and you can crossfire it later. The GTX465 from nvidia will go head-to-head with a 5850 for performance and scales very well in SLI ... but nvidia are struggling with their architecture right now whereas ATI's setup has been pretty elegant.
  11. somewhereoveryonda
    6 May 2010
    Thank you for all the advice!
    As far as a second hand card goes I'm not too keen... I really would prefer to buy new and know it hadn't been OC'd to infinity and was just about to give up!
    I did look at the 465 originally, but as suggested the price doesnt satisfy the performance. Will physx be a big loss? :jawdrop:
    I have taken a look at the Saphire 5850 toxic, which is out of stock atm at scan. Is there a chance it is end of line? The XFX black has similar specs for £20 less.. is this an equally good buy? How does support etc stand on these?
  12. somewhereoveryonda
    6 May 2010
    I did see that actually! A bit odd... Could be either lol
    Yeah it will be built to last for about 4 years so DX11 would be handy.
    I read a review somewhere on the GTX 465 and the 5850 came out on top most of the way apart from COD MOD2.
    So it will be a 5850.. Does anyone have any recommendations on which one?
    Thank you!
  13. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    I would go for an Asus 5850, as it comes with a 3 year warranty and voltage tweaking ability...
    ________
    Philippine girl Webcams
  14. somewhereoveryonda
    6 May 2010
    Their custom cooler doesnt direct airflow out of the case.. is this not a big issue?
  15. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    You could strap an aftermarket cooler on it but that'd void your warranty.
    EDIT: If you have good airflow in your case then it should be fine anyway, it's just nice having the extra ehaust.
  16. shah
    shah Minimodder
    29 Jan 2010
  17. fingerbob69
    5 Jul 2009
  18. Pete J
    Pete J Employed scum
    28 Sep 2009
    Are you feeling all right? It looks as though you gave a Fermi card a possible recommendation! :D
    Yeah, £250 is perfect 5850 territory.
    You could also be daring and go for 2x5770 crossfire - it can give you performance comparable to a 5870 or more!
    Edit: Get 3GB more RAM!
  19. Sexton
    Sexton Minimodder
    2 Jun 2010
    Fermi cards are amazing for those who don't like ATI - like me. My past ATI cards have all been crap - unreliable, cheap, nasty and impossible to overclock without blowing up - overall awful. I would therefore be happy to pay whatever amount for an NVIDIA card, because I know they are reliable and overclock well :) Also the ATI drivers are the most awful, unstable piece of s**t I have ever had the misfortune to use... the amount of problems I had. Numerous BSODs, inability to play some games on high settings because drivers couldn't handle it - just ridiculous. NVIDIA all the way for me :)
    For £250 I would recommend a GTX 285 (http://www.scan.co.uk/Products/1GB-...GPU-648MHz-Shader-1476MHz-240-Cores-2x-DL-DVI). If you're OK with ATI then a 5850 (http://www.scan.co.uk/Products/1GB-...DDR5-GPU-735MHz-1440Cores-2x-DL-DVI-I-HDMI-DP) would be your best bet.
  20. Pete J
    28 Sep 2009
