Build Advice £250 Upgrade Budget
Discussion in 'Hardware' started by Kronos, 24 Jun 2013.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    £250 to spend with current specs:
    XFX Radeon 6870 1gb GPU
    8150 Bulldoxer 3.6ghz 8 core CPU.
    Kingston 4GB DDR3 1600Mhz x2 RAM.
    Asus M5A78L/USB3 Motherboard.
    Win 7 64 bit.
    Looking for upgrade suggestions.
    Not my specs I might add.
  2. mrbungle
    20 Sep 2004
    Motherboard is a low end 4 phase design which isn't ideal with FX cpu's
    That said if the system is stock it will prob be fine (would imagine it will throttle when those bare vrm's get too hot).
    The GPU is getting on now, if that were my system id prob pick up a 7950, maybe then look at a ssd with the remainder.
  3. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    SSD first.
    Then GPU.
    Depends on what it is being used for. But that is the order I would upgrade in.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    I believe he is looking to do a bit more gaming on it so I would suggest he would need to upgrade GPU and then SSD.
  5. Harlequin
    Harlequin Modder
    4 Jun 2004
    ssd and a mosfet heatsink IMO - I added an enzotech MST-81 to my board and holy **** it gets warm (gigabyte ga770ta-ud3, with 8+2)
  6. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    For gaming a new GPU. Any mid-high end card will beat your current one.
    For all round usage, a new SSD. Install your OS on it and it will reduce the time to do everything.
  7. Shirty
    18 Apr 1982
    Framerates need GPUs, so that's the answer. Probably pick up a second hand 680 or a 7970 GHz for that sort of money, but if not then a 670 or 7950 new.
    David and YEHBABY like this.
  8. Harlequin
    Harlequin Modder
    4 Jun 2004
    ocuk have a KFa2 gtx 670 for £239
  9. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    The CPU is fine, it'll more than come into its own once the new consoles hit. I would be adding a nice high end GPU :)
  10. Guest-56605
    Guest-56605 Guest
    • GPU
    • SSD
    In that order :)
