Build Advice £300 CPU/MB/RAM/GFX
Discussion in 'Hardware' started by Tinners24, 19 May 2009.
  1. Tinners24
    Tinners24 What's a Dremel?
    19 May 2009
    Hi,
    I'm upgrading a mate's old AthlonXP 3200+ machine to something a bit quicker.
    Budget is around £300 for CPU, Motherboard, RAM and GPU. For general use and gaming.
    There's a few options i've considered but I'm struggling to decide:
    CPU: Pentium E5200 £55 / Core2Duo E8200 £105 / Core2Quad 6700 £138
    Motherboard: MSI P43 Neo-F £61 / Biostar TP45 HP £89
    RAM: Whatever 4GB DDR2800 kit is best value (probably Corsair TwinX) £40
    GPU: 512MB HD 4770 £80 / Geforce 260 £138
    I've also looked at the Phenom II X3 720 BE which seems like a good proposition too.
    Any thoughts/suggestions on this would be appreciated.
    Thanks.
  2. SazBard
    SazBard 10 PRINT "C64 FTW"
    28 Apr 2009
    does his current motherboard use socket 939?
    Also what PSU has he got?
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    It'll be socket A (462).
    Have you factored in a new PSU? He'll need a new one probably, even it is only a 400W Enermax or Corsair unit.
    Personally I'd get the HD4770 and the MSI board with whichever CPU fits the budget.
  4. Unicorn
    25 Jul 2006
    Good luck to be honest. A gaming machine that will run modern games for £300 is a BIG ask. I did basically the same thing for a friend of mine lately at a friend price, and it cost about £550. That was a video editing rig though, for logging and editing DV.
  5. ch424
    ch424 Design Warrior
    26 May 2004
    Go on aria.co.uk and look for bargains in the superspecials section...
    Asus HD4850 - £100
    4GB PC-6400 - £40
    Freezer 7 Pro - £15
    Gigabyte EP43-DS3L - £68
    Intel 5200 - £54
    delivery - £7
    comes to about £270, leaving room to swap the 4850 for a 4870, or perhaps a better CPU, or a cheap PSU if he needs it...
  6. alastor
    alastor Minimodder
    6 Sep 2004
    Just very quickly specced up a system:
    Corsair PSU 400W CX400W
    Intel CPU Dual Core E5200 2.5GHz 800FSB LGA775 2MB cache Retail inc.Fan
    Gigabyte motherboard GA-EP43-S3L
    Corsair memory 4GB TwinX XMS2 6400 DDR2 Kit (2 x 2048MB)
    XFX ATI Radeon 4770 512MB DDR5 PCI-E DVI
    Total price including VAT £293.63
    It's very do-able, could even throw in an Akasa 965 if you can find another £5 :thumb:
  7. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    I would take a good look at his PSU to see if it would cope with a power hungry graphics card.
    What rating it is and what pci-e conections it has.
    From sounds of it you will likely need to work a PSU into the budget, you could do that by going for the E5200 CPU though.
  8. Tinners24
    19 May 2009
    He has a 480W XClio PSU (think its rebranded FSP) that i made him get a year or so ago. I reckon it should be able to cope
  9. bagman
    bagman Minimodder
    18 Apr 2009
    mobo gigabyte p31 ds3l=53
    cpu e5200=55
    ram 2gb corsair 800mhz=£26
    gpu 4890=163
    total=297
  10. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    It's all depentant on what resolution the games are run at, £300 is possible to build what i would call a mid range gaming system.
    A 4830 from ATI is well under £100 aswell as there 4770. Nvidia's 9600GSO is in the same price range.
    So factor in £100 for a mid range motherboard, and £100 for CPU/memory combo, that still leaves spare change.
    So a system based around a E5200 and 4GB ram is more than possible, and will be pleanty powerful. Even has a decent headroom for an overclock!
  11. Geiseric
    Geiseric X CPC Forum Stalker
    23 Apr 2009
    I was a big fan of the P31-DS-3L but it really has reached the end of it's life with no support for PCI-E 2.0, limited over-clock on 333FSB CPU's and the lack of stability when using more than 2 memory modules. A good replacement is the Gigabyte GA-EP43-S3L that solves all the problems for another Tenner.
  12. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    +1 i have the P31-DS3L and will probably run it till it dies, at the time it was amazing but there are better options for a little more money now
    having said that i would always go for gigabyte at the lower end of the market, you just get more features for your money
  13. SazBard
    28 Apr 2009
    I would get a
    Biostar TP45 HP (new £88 frm scan)
    Intel e7400 (new £96 frm scan)
    Corsair TwinX XMS2 PC2-6400 (new £27 frm scan)
    8800GT 1GB Alpha Dog (Graded £65 inc delivery videocardshop.co.uk)
    = just under £300, you will probably pay £8 to scan for delivery.
