Storage £300 to spend on a SSD, (which one? ordering by 5pm)
Discussion in 'Hardware' started by Guest-44432, 1 Jun 2010.
  1. Guest-44432
    Guest-44432 Guest
    SSD for windows only. I have a budget of £300 so I'm looking to go for best performance by either 1 fast SSD or 2 in raid 0. Storage size doesn't matter as its only going to store windows (40gb+)
    Simon.
  2. olimorgan
    olimorgan What's a Dremel?
    16 May 2010
    Intel seems to get good reviews
  3. Ergath
    Ergath Giant Zombie Pigeon Photographer
    6 May 2009
    I wouldn't bother with RAID 0 - don't think it's worthwhile with SSDs (if at all). £300 gets you a nice 100/128GB SSD - you may want to consider one of the new OCZ Vertex 2 drives, or perhaps a Corsair Nova.
    I strongly suggest that you read all of the SSD reviews on Bit-Tech, and fill in the gaps from elsewhere - there are a number of pitfalls waiting to claim unwary SSD purchasers.
  4. AndyCubb
    AndyCubb Victory is mine!
    21 May 2010
    One thing I have always wondered with SSD's is that being so small in capacity (for reasonable prices) if I stick my OS on it and say Steam and all games on D: drive am I going to notice any difference in games?
  5. Slizza
    Slizza beautiful to demons
    23 Apr 2009
  6. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    if you can stretch to another 30 quid then the 160gb intel fits the bill pefectly - i cant complain since i got mine, its awesome.
  7. Guest-44432
    Guest-44432 Guest
    Hi, yes I can stretch to the extra £30 the £300 was a figure for you guys to work with.
    Cheers,
    Simon.
  8. Slizza
    23 Apr 2009
    The intel drives are slower though.
    70mb/sec write speeds...poo.
    That's £130 more for a much slower drive (write speeds) with a extra 32 gb ...
    Seems a no brainer.
  9. barndoor101
    25 Oct 2009
    you dont know what you are talking about.
    70mb/s is for random writes - other drives give their sequential write speeds because their random writes are so bad. the kingston drives have great sequential write speeds as their random writes suck balls.
    in the end 4k writes are the most important stat as you shouldnt be using an SSD as a storage drive (ie where sequential writes do matter).
    here is the BT review of the g.skill falcon 2 (itself a very good SSD):
    http://www.bit-tech.net/hardware/storage/2009/06/24/g-skill-falcon-128gb-review/6
    every drive gets outclassed by the intel drive in the random speeds
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I think you need to learn the difference between sustained read/write speeds, which are the speeds manufacturers quote, and random read/write speeds, which Intel drives obliterate virtually every drive at. And ask yourself, when your booting up your computer, or a program, or a game, are you reading one enormous file, or lots of small ones?
    EDIT: In the last hardware podcast, they said that the best selling SSD in the UK by a huge margin were the Intel drives as they are good value for money in both capacity and speed. The Vertex/Corsair drives are extremely fast but poor value for money as you get a very small drive for your money.
    http://www.bit-tech.net/hardware/storage/2009/06/24/g-skill-falcon-128gb-review/7
    Random writes 4 times faster than rival drives.
  11. Guest-44432
    Guest-44432 Guest
  12. StephenK
    StephenK Sneak 'em Upper
    21 Dec 2006
    My mate has the x-25 and loves it. Very nippy and he keeps win7 and all his games on it. He's a very happy boy and I'm currently saving up to get one myself.
  13. barndoor101
    25 Oct 2009
  14. Guest-44432
    Guest-44432 Guest
    Right, I'm ordering the Intel x25 160GB.
    Thanks for the advise guys.
    Cheers,
    Simon.
  15. Guest-44432
    Guest-44432 Guest
  16. barndoor101
    25 Oct 2009
    dont use google checkout on aria. they ****ed up my order with them (coincidentally a 160gb x-25m aswell) - they took the money out but wouldnt send the drive. so i cancelled and bought from scan (worked out about the same as i get free delivery from scan) and got it next day.
    Guest-44432 likes this.
  17. knuck
    knuck Hate your face
    25 Jan 2002
    On a 32 player server in TF2 I can get in the game and be alone for about 15secs before anyone arrives. It's awesome :D
    There are few UT2K4 maps that take 1 or 2 seconds to load. Bad Company 2 also loads quite fast although not as impressively. Crysis still and will always take forever though.
  18. Ph4ZeD
    22 Jul 2009
    BC2 is cool because you can load into the map before anyone else and get any vehicle of your choice :)
  19. Guest-44432
    Guest-44432 Guest
    Dammit, I forgot about the free delivery with scan. To late now. I didn't use Google checkout to pay.
    But thanks for the heads up.
    Also added +1 rep for the advice :thumb:
    Cheers,
    Simon.
  20. Guest-44432
    Guest-44432 Guest
    Ha, I will be using that to my advantage. Better not play on the same map as you tho. Lol
