Build Advice £400 Small, stylish home PC
Discussion in 'Hardware' started by 6032wayne, 11 Sep 2012.
  1. 6032wayne
    6032wayne What's a Dremel?
    15 Mar 2012
    Budget: £400 (Absolute max of £450)
    Main uses of intended build: internet, Microsoft Office, media storage, main household music player, media storage and photo viewing. If possible, I may end up playing Football Manager and Starters Orders but not fussed on this.
    Parts required: Everything
    Previous build information (list details of parts): None
    Monitor resolution: 1080p
    Storage requirements: 2TB
    will you be overclocking: no
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): Would like an internal card reader if possible and a minimum of 4 USB ports.
    Extra information about desired system: I want something small and preferably stylish as this will be on view in my living room (red would be good lol but not too fussed lol), something that could handle listening to some tunes whilst I typed a few letters, sorted a few photos etc. without having to close things down if you know what I mean.
    Cheers :D
  2. 6032wayne
    15 Mar 2012
    Here's what I've come up with so far. Really struggling with the PSU as I can't tell if they'll fit in the selected case...
    Case: X-Case X301 (Black/Red) - £40
    Processor: Intel Celeron G530 2.4GHz - £45
    Mobo: ASRock Z77 Pro4-M Intel Z77 - £80
    HDD: Seagate Barracuda Green 2TB - £100
    DVD: Samsung SH-S222BB/RSMS 22x DVD+-RW - £20
    Card Reader: Akasa USB 3.0 Memory Card Reader - £15
    PSU: ... £50
    Memory: Kingston HyperX Blu 4GB 1333MHz - £25
    Total including roughly what I think I'll need to spend on a PSU is £375 so there is room in the budget if anyone can see any obvious improvement???
    Thanks!
  3. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You could save some money by getting an H77 motherboard -- the Z77 is only worth it if you're overclocking, which I don't think that CPU supports.
    Maybe you could squeeze in a cheap SSD? That would be a huge improvement for the system disk over the Green HDD.
  4. maple
    maple Minimodder
    23 Feb 2012
    Buying a more higher end board to go with a G530 makes no sense at all, you could get a H61board for as little as £32 there is a G540 which is slightly better than the G530 and it can be had for just above £25 from novatech.
    Also you definately want an SSD in there they are just too cheap now to not consider it
    64GB £29.99 - 128GB £49.99 though it does depend which you get, scan do have some good deals on ssds from time to time also its worth checking the 'today only' stuff too
  5. 6032wayne
    15 Mar 2012
    Thanks for the replies :D
    I'll change the motherboard to the following... ASRock H77M which is about £55 to £60ish, it's the cheapest I can find that still has SATA III available.
    How much difference would an SSD system drive actually make to me and what's the smallest I'd need for OS and a few basic programs??
    Cheers again!
  6. oliverr97
    oliverr97 What's a Dremel?
    31 Jul 2011
    A 64gb ssd should be fine for a boot drive and you really do notice the speed increase, so i highly recommend one :)
  7. 6032wayne
    15 Mar 2012
    I think I'm gonna give the SSD a miss at the moment, the case I like has room for one optical drive and two HDD drives or one HDD and one card reader, I really don't want to have to get an external card reader!
    Updated specs after more research:
    Case: X-Case X301 - £40
    CPU: Intel Pentium G840 2.8GHz - £50
    Mobo: MSI B75MA-P45 - £50
    Card: Akasa USB 3.0 Memory card reader - £15
    PSU: 300w Be Quiet BN133 SFX - £40
    RAM: Kingston HyperX Blu 4GB 1333MHz - £25
    Total cost so far: £340
    Anywhere I can improve further???
    Thanks :D
  8. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
  9. shah
    shah Minimodder
    29 Jan 2010
    Why your HDD is costing £100? when you can pick one up for about £80.. so you might consider a SSD? 60gb for about £30?
  10. shah
    shah Minimodder
    29 Jan 2010
    Landy beat me to it
  11. 6032wayne
    15 Mar 2012
    Haven't researched prices fully yet lol, just using the first prices that pop up in google shopping for now!
    I think I'll get the WD Caviar Green, thanks! I'd like a SSD but I really need that internal card reader and there is only space for one or the other...
  12. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    Ssd's are quite small, they have no moving parts so you can pretty much Velcro it anywhere. It doesn't need a drive bay
  13. mm vr
    18 Nov 2007
    This. My SSD isn't attached to anything except the cables. SSDs are really small (2.5" laptop HDD size but half the thickness) and light and don't vibrate the slightest.
  14. 6032wayne
    15 Mar 2012
    In that case, it's looking like I'm going to have £60 to £80 left over, which SSD would be recommended?? If I can get 128Gb for that, I'd rather do that than get a slightly better performing 60GB... :D
  15. richythomas
    richythomas Minimodder
    29 Apr 2009
    I'll also agree with the SSD's can be placed anywhere as both of mine are velcro'd out of sight too the back of the motherboard tray which means I still have two HDD bays free for mechanical drives (actually three bays but my RAM intrudes on power/SATA cabling for a third drive). I bought some velcro discs from Halfords for a couple of pounds which does the job nicely.
    I've got a couple of Crucial M4 256GB's so I'd recommend the 128GB version without question although the write performance is a little lower on M4 128GB but you probably won't notice in day-to-day tasks (I used to have a Crucial C300 128GB and in real world tasks I can't really tell the difference).
    Samsung 830's are worth a look and are very popular around here (probably because they are extremely fast and price is near enough in line with the M4's!).
    Crucial M4 128GB - £79.34
    http://www.scan.co.uk/products/128g...-flash-read-500mb-s-write-175mb-s-new-version
    Samsung 830 128GB - £82.94
    http://www.scan.co.uk/products/128g...basic-kit-sata-iii-read-520mb-s-write-320mb-s
