Notebooks £500 laptop
Discussion in 'Hardware' started by fdbh96, 4 Aug 2011.
  1. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I am looking for a laptop that is around the £500 Mark (£550 the absolute limit)
    I have seen a lenovo z570 on pc world for £479 with an 2nd gen i5 and 4th of ram.
    On saveonlaptops.co.uk there are multiple options for it. Would it be worth dropping the CPU to an i3 and get a gt520m. Or get the i5 and gt520m (will it make much difference).
    The main uses will be web browsing, films and some light gaming when away from my pc. Likely games are civilisation 5 and age of mythology.
  2. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Depite the relatively light use I would always plump for the i5 2xxx over the i3 2xxx in the mobile series, if only to get the turbo feature.
    Thanks to the relatively low stock frequencies on the SB mobile series the turbo feature really comes into its own.
    Have a look on www.dmxdimension.com to see if there might be a XPS15 or Inspirion 15R which might suit your requirements. They link you to the best offers available direct from dell and tell you the latest coupon codes to get further money off.
  3. fdbh96
    29 May 2011
    I should have said that i'm not keen on dell laptops, and they are still a bit expensive @ £600 for dell equivalent to the lenovo i5 no dedicated GPU.
  4. xaser04
    27 Jun 2008
    Intel Core i5 2410M 2.30GHz
    Windows 7 Home Premium
    15.6" High Definition (1366x768) WLED
    4096MB
    500GB
    1GB Nvidia GeForce GT 525M
    DVD Writer
    £579 - £30 with coupon
    N00Q1535
    The XPS15 looks to be around the £600 mark for the same spec.
  5. fdbh96
    29 May 2011
    Yeh but the dell keyboards feel horrible and aren't known for their build quality. Someone I know has an xps 17 and i don't really like the keyboard and it has lots if flex in it. The good thing is that they come with a 7200rpm hdd as standard.
  6. MrP
    MrP seeking inspiration
    5 Jul 2007
    kinda on the same subject, but a lower price (so sorry for the hijack)
    i have been looking for a new laptops to replace my very aged tosh L20
    http://www.saveonlaptops.co.uk/Dell_Inspiron_15R_1085130.html
    this is my current favourite to replace it with.
    all its gonna be doing is web browsing, some iplayer (and varients), playing some WOW, and some trackmania.
    the nice GPU has drawn me towards it, but does anyone have any comments on the inspiron, or a better alternative for the same kind of money
    thanks
  7. djDEATH
    djDEATH Habari gani?
    23 Mar 2006
    I just bought a Dell 15" 5110 from ebay - brand new, for £370 - delivered.
    Its awesome, and probably as powerful and snappy as my desktop.
    I needed it for going back to Africa, netbooks just don't cut it for me, and I want my gaming fix when up on Kilimanjaro!!
    Core i3-2310M 2.1Ghz
    Intel HD3000 Sandy bridge Graphics
    NVIDIA GT525M 1GB (with Nvidia Optimus)
    HDMI 4.0 with 3d Support
    Intel Wireless Display
    4GB (1 soDIMM - 1 slot free) 1333 DDR3
    500GB 7200rpm drive (surprisingly fast)
    All wireless N, bluetooth 3.0, USB 3.0 eSATA etc etc
    Now OK, it isn't the prettiest or most well built or lightest laptop you can buy, but for £400, where else will you get a full on gaming machine - with 5+ hours battery life for general tasks (10-15% screen brightness - wireless on, power saving max) and over 120minutes gaming on 50% brightness???
    Lenovo IdeaPads are quite nice too, but a little more expensive, but I can confirm that the i3-2310 is more than enough for modern games, the bottle neck will still be the GPU, even with 96 stream processors at 600Mhz (same number as a 9600GT desktop card if i'm not mistaken).
    Keyboard has some flex, and there are issues with the wireless card (google "Intel 1030N issues") but once you realise that it doesn't support TKIP properly and use AES instead, those issues do go away.
    I got this, and then bought a refurb HP 2510p with an extended battery for when I'm travelling, the inspiron will be in my house up on the mountain, ready for me to frag away when the power cuts hit in, and continue web surfing and poker playing long into the night on my 2510p when the main one runs out of juice.
  8. djDEATH
    23 Mar 2006
    Inspiron 15R N5110 w/Nvidia GT525M + i3-2310M
    I can also confirm:
    F1 2010 runs on HIGH, native res 1366x768 @ 40-50fps
    Race07 runs MAXED OUT with 8xQ AA @ 75-90fps
    Left4Dead over 120fps
    Modern Warfare 2 @ 45fps on High
    What more do you need???
  9. MrP
    5 Jul 2007
    an ebay link please!
  10. djDEATH
    23 Mar 2006
    http://computers.shop.ebay.co.uk/La...=n5110&_catref=1&_fln=1&_trksid=p3286.c0.m282
    Check the specs (always contact seller for detailed info) and make sure you get the GT525M as well as the onboard intel graphics (does cool power saving switching with no lag or errors).
    Look out for others in the range, you can get an i7 Quad on this machine, but seems like overkill given the maximum GPU is a 525M and it will only eat up more power.. each to their own i guess and how much you wanna spend.
    Mine was £370 buy it now (look at completed listings in last week) but it looks like there is one for £279.99 with the same spec. I paid the extra to ensure it still had full MFR warranty etc, as I'm taking it with me to Africa in October for a year and a half.
    Happy bidding!!! ;)
  11. fdbh96
    29 May 2011
    does anyone know how the g520m performs compared to the g525m
  12. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    could anyone suggest a 13" chassis notebook for £4-500 that will do some gaming? its a big ask i know but i dont want amazing performance just the ability to play games occasionally when im away from my rig. how are the AMD fusion CPU's for this? from experience i know intel 3000 isnt great
  13. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
  14. MrP
    5 Jul 2007
    dunno, having said i fancy the dell above, i now fancy the acer 5750g, but does anyone think its worth waiting for the llano based laptops
  15. [PUNK] crompers
    20 May 2008
    just ordered an alienware m11x rev. 1 £500 on amazon, will let you know how it goes
