Notebooks £500 to spend on laptop
Discussion in 'Hardware' started by freedom810, 11 Apr 2008.
  1. freedom810
    freedom810 Minimodder
    3 Dec 2007
    Just wodnering what i can get, i was looking at getting roughly these specs,
    2gb ram
    1.6Ghz + dual core
    8600GT
    100gb hardrive+
    Was pondering over the dell vostro 1700 with similar specs but it would be kind of heavy with a 17" and it seems more expensive with the smaller vostro 1500. Was just wondering if you guys have any ideas at all.
    Help would be much apreciated.
    ive got £500 to spend though could push if i really liked it too £550
    Thanks for the help.:D
  2. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Ebuyer are selling the 17" HP Pavilion DV9720EA for £540 (delivered) :idea:
    Specs include:
    17" WXGA+ 'BrightView' Widescreen (1440 x 900)
    AMD Turion 64 X2 TL-64 @ 2.2GHz
    2GB (2x 1GB) DDR II @ 667MHz
    (128MB?) nVidia GeForce 7150M (up to 559MB total available)
    250GB (5400rpm) SATA
    Dual-Layer Super-Multi DVD±RW with LightScribe
    Webcam
    Ethernet 10/100BT integrated network interface 802.11b/g WLAN
    5-in-1 Card Reader
    ExpressCard slot
    HP Mobile Remote Control
    90W AC Power Adapter + 8-cell Lithium-Ion (Li-Ion) battery
    Vista Home Premium 32bit
    Warranty: 1 year pick-up and return (parts and labour)
    Weight: 3.55kg / 7.8lbs
    I have an older 17" HP Pavilion ZD8228EA meself, and I love it. My son thinks the same of his 15.4" HP Pavilion DV6231 :cooldude:
    It's quiet in normal use, and the keyboard is the best laptop keyboard I've ever used :clap:
    If you want an Intel-based laptop... Scan are selling the 17" Acer Aspire 9423WSMi for £419.99 / £493.49.
    Specs include:
    17.1" (1440 x 900)
    Intel Centrino Core 2 Duo T5500 @ 1.6GHz
    2GB (2x 1GB) DDR 2 @ 667MHz (Max = 4GB)
    128MB nVidia Geforce Go 7300
    160GB (5400rpm) SATA HDD
    Super-Multi DVD±RW
    1.3MP Webcam
    5-in-1Card Reader
    Windows Vista Ultimate
    6-cell battery
    Weight: 3.7Kg (/8lbs?)
  3. freedom810
    3 Dec 2007
    Wow thanks for the post, ill take them both into consideration :)
  4. atanum141
    22 Jul 2004
  5. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    I've gone for the vostro 1700
    waiting for dell to build and send it to me.
    only downside I see is that is is heavier than others.
    I only paid £533 for mine.
