Build Advice £5k PC for a friend
Discussion in 'Hardware' started by Bloody_Pete, 29 Mar 2020.
  1. Vault-Tec
    30 Aug 2015
    Bloody_Pete likes this.
  2. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    That was just a 'for example', not a 'buy this'... would do for me, with a 32" super wide, a k/b & mouse.
    Aren't SSI 'boards for servers...?
  3. Vault-Tec
    30 Aug 2015
    lol tell him you'll slap him if he buys that PSU :D
  4. Jeff Hine
    8 May 2009
    A 1000W unit would be more than enough for that list... :eek:
  5. Vault-Tec
    30 Aug 2015
    Dude look at it, then tell me what's wrong with it.
    GeorgeK likes this.
  6. GeorgeK
    18 Sep 2010
    But it's a GameMax, what could be better - like GAME TO THE MAX DOOD.
    Also it's a mining PSU, has a squllion PCIe and molex connectors, and is almost a foot long
  7. Vault-Tec
    30 Aug 2015
    2000w, no wait 1800w and a 92mm fan.
  8. Jeff Hine
    8 May 2009
    Ohh... you mean the fluorescent lime green livery...?
  9. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I didn't even notice that part!
  10. Bloody_Pete
    11 Aug 2008
    I'm alsso curious why he chose a 500GB HDD along side the 1TB SSD and 16TB HDD. Its just very odd! My only reason for going Intel is I want to see 5GHz with my bare eyes!
  11. Jeff Hine
    8 May 2009
    SSD 1 - system/Windows
    SSD 2 - Games/Programs/etc
    HDD's - Data/files.
    Same way I have my current rig set up; 250GB Windows//500GB Games//1TB data/files//500GB 'Back-up'; I know it ain't a brilliant 'solution' - with egregious points of failure - but it works for me.
  12. Vault-Tec
    30 Aug 2015
    5ghz only went so far. Then AMD came out with Ryzen 3900x and 3950x and it was all over. Their next plan? a 10 core. on 14nm++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
  13. Bloody_Pete
    11 Aug 2008
    From todays leaks, looks like they're doing 5.3GHz 8c/16t on mobile! Which is fairly bonkers! The poor engineers who had to get those instructionbs performing at that speed are unsung heros :p
  14. Vault-Tec
    30 Aug 2015
    That is what the ad shows. There is a 3 next to it, which probably means it is catch #3. IE single core boost, non avx, not sustainable. BS, in other words.
  15. Bloody_Pete
    11 Aug 2008
    It'll be 'under suitable power and thermal conditions'.
  16. Vault-Tec
    30 Aug 2015
    *for about two seconds.
