Graphics £60 Budget GPU
Discussion in 'Hardware' started by drjaydee, 13 Nov 2011.
  1. drjaydee
    drjaydee What's a Dremel?
    1 Sep 2009
    A friend is after a graphics card on a £60 budget.
    I'm completely at a loss as to what to advise him, which cards have aged the best?
    Any suggestions are very appreciated, doesn't matter if it's 2nd hand.
    Cheers
    Nick
  2. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I got my GTX460 for £64, so it's something to aim for, still a very capable GPU for that kind of money. Next best would be something from Nvidia's last line, like the GTX285 which can be had at a similar price.
    As for AMD, the 4890 isn't quite up to the same standard and the 5850 is way too expensive. :thumb:
  3. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    You got a good deal, I was gonna say there was a gtx 275 in the market place, very capable card.
  4. tonpal
    tonpal What's a Dremel?
    27 Jul 2008
    Radeon 5770s go for around £50 on ebay, with postage that should come out around the £60 budget.
    £64 for a GTX460 sounds like a good deal, if your friend can find something similar he should jump at it.
  5. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    +1 on the gtx 275. Very, very good card and very capable in this day and age.
  6. Tangster
    23 May 2009
    I've seen some HD5850's going for that price as well. They hold up pretty well as long as you don't pile on the tessellation.
  7. LennyRhys
    LennyRhys Oink!
    16 May 2011
    5850s for £60? I'm dubious about that... they are in £100 territory, just like the GTX470 which they more-or-less match in performance.
  8. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    you can get a ati 4870 1gb on ebay for about £35
    2 of those in xfire are still pretty damn good
    obviously if you dont mind it not being dx11
  9. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    I've seen HD5770's around £55-£65, HD5850's around £85, the GTX460's around £75-£80.
    These are used prices last time I looked.
    GL.
  10. Parge
    16 Jul 2010
    Yeah, best you are going to get for £60 is probably a GTX 275. Maybe if he stretches to £70 you might be able to find a 768 GTX 460 which would be a far far better option.
  11. AoE
    AoE What's a Dremel?
    4 Oct 2011
  12. rob the bank
    rob the bank What's a Dremel?
    13 Mar 2010
    Do you know what PSU and case he has?
    Nothing worse then a £50 bargain ending up costing £100 to use :=)
    Although that’s the slippery slope of PC up-grades.
    If he has a pretty low spec PC to start with then the 5770 would probably be the best move as it runs pretty cool and is not too hungry when it comes to juice.
