Graphics £60 graphics card
Discussion in 'Hardware' started by Murdoc, 1 Jun 2009.
  1. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Hello bit,
    I'm after a graphics card for my fathers PC, its a core 2 duo something (built it last year and can't remember!) it has on board graphics so I'm looking to upgraded it to play the odd game for his birthday.
    The two cards at this price point seem to be the Radeon HD 4670 and Nvidia 9600GT in reviews both seem to be similarly matched. So any advice or other options?
    Cheers.
  2. bagman
    bagman Minimodder
    18 Apr 2009
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    You're better off buying from Scan than Videocardshop, they do refurbs.
    Here's a 9600 on Scan (£64)
  4. mrbungle
    20 Sep 2004
    Scour ebay.
    I just got a brand new HD3850 for £35 delivered :D
  5. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    You have checked it has a suitable PCI-E slot available?
    some mobo's don't?
  6. Unicorn
    25 Jul 2006
    If it's a C2D machine built last year I'm willing to bet that it has a PCI-E slot, even if it does have onboard graphics as well.
    The 9600GSO is a good call, as is the 3850 if you can get one as cheap as £35! :jawdrop:
  7. Murdoc
    25 Jul 2003
    Yup it has a PCIe slot.
  8. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    8800GT
    With shipping its a couple of quid over £60
  9. Elton
    23 Jan 2009
    You could opt for a 9600GT, which can be had for about 45 quid if you shop around.
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    Is the 9600GSO just an overclocked 9600GT?
    I would say HD 4770 if you can find one.
