PSU <£60 PSU
Discussion in 'Hardware' started by Zinfandel, 11 Jun 2011.
  1. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    So I need a PSU. It will never be powering more than a mid ranged GPU (560 at absolute max but more likely 550 or similar ATI) and low to mid range CPU with 4gb of ram, 2HD.
    PSU list is a bit out of date so I thought I'd ask you fine folk for your opinions!
    Thanks very much
    Ash
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Would have thought Corsair CX500 would be good for most cases.
    Is a version 2 with some improved components incoming over the next few days/weeks so I'd wait for that.
  3. Instagib
    Instagib Minimodder
    12 Mar 2010
    This one looks good. On the limit of your budget, but should allow for plenty of upgrades down the line; plenty of power on tap here.
  4. Tangster
    23 May 2009
    Silverstone Strider 500W?
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Antec High current Gamer 620w (currently £47.99 on Scan's Today Only page)
    Corsair Builder Series 600w V2 (don't forget the V2 bit, £50.38 on Scan - not Today Only though)
    If you want to stretch another £5.99, you can get the CoolerMaster Silent Pro M (modular) for £65.99 on Scan's Today Only.
  6. KD88
    KD88 Minimodder
    25 Aug 2009
  7. Spanky
    Spanky Minimodder
    14 Apr 2010
    The Be Quiet is a very good PSU for £45. I would imagine that 530w will suit most needs if your not into SLI/XFIRE. I had one to power a P55 with an i5 750@ 3.83Ghz also a ATI 5850. Very very quiet indeed.
    1 thing to remember is that the cables are not braded, and this is a real shame, other than that its a very solid peice of kit and somthing that i will use again in the future.
    http://www.overclockers.co.uk/showproduct.php?prodid=CA-042-BQ&groupid=701&catid=123&subcat=1083
  8. Guest-23315
    Guest-23315 Guest
    I just got one and its fab :thumb:
  9. Blogins
    3 Aug 2010
    The version 2?
    I got the CX500 as a downgrade when it was on special through SCAN to replace my SLI powering Enermax Galaxy 850W! Now my 500W UPS can actually support my old CPU should the power cut as it sometimes does!
