Displays £650 display set up
Discussion in 'Hardware' started by longweight, 18 Jul 2011.
  1. longweight
    7 May 2011
    Hi all,
    title says it all really! I have £650 to spend on a display set up for my new PC. PC Spec is:
    i5 2500K
    EVGA GTX 570
    8Gb DDR3 Ram
    I am not sure whether I should go with one IPS 27" monitor or 2 smaller ones? I want the 16:10 ratio for gaming and a larger working area should I start to work from home in the near future.
    Been looking at the Dell U2711 but it appears to be 16:9 not 16:10 so any other suggestions?
    Thanks
    Long
  2. Guest-44432
    Guest-44432 Guest
    Here's a linkBodkin is selling a 30" Monitor in the Market place for £650 delivered.
  3. longweight
    7 May 2011
    AH thanks man, I was very close to buying but I would like to get something new....
  4. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    What about 3xdell u2311h in either landscape or maybe portrait mode for lots of space :)
  5. longweight
    7 May 2011
    Would my GTX 570 handle that? 1.2Gb VRAM
  6. fdbh96
    29 May 2011
    I would say so but not on the highest settings as the bandwidth (right word?) on a single card might bottleneck the performance :(
  7. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Dell U2410 ? for the 16:10 aspect ratio and then a separate U2311H for gaming/watching movie? :)
  8. longweight
    7 May 2011
    Hmm but then they wouldn't match :(
  9. thetrashcanman
    18 Nov 2010
    true, get one u2410 now and save up for another one? Also remember, when running 2 monitor's of a single nvidia card, I believe they turn themselves (stupidly) upto 3d clocks or something, so start to get quite hot and loud as the fan's ramp up.
  10. Huge
    Huge aka Dave
    11 Jul 2011
    Not sure if Nvidia cards support more than two monitors but my setup is a 22" widescreen with two 19" 4:3s on either side (all dell ultrasharps and all the same height). Perhaps do something similar but with a 24" in the middle and larger FPs on either side?
  11. thetrashcanman
    18 Nov 2010
    Unfortunately they don't D: silly @ OP you need to Nvidia card's to be able to run 3 monitors
  12. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Nope - with both of my displays enabled in windows (which isn't often) my graphics clocks don't change, nor does the card get hotter - sits at 34C pretty much all the time, regardless of what display config I use.
  13. GeneGenie
    GeneGenie What's a Dremel?
    8 May 2011
    My GTX 570 gets hotter when both my monitors are connected. I believe this doesn't happen if your monitors are identical.
  14. longweight
    7 May 2011
    Well I have my GTX 570 now :(
  15. fdbh96
    29 May 2011
    Tbh I think (in opposition to my previous post) that a single dell27" would be better as you could play on higher settings and maybe get 2 smaller monitors later :)
  16. longweight
    7 May 2011
    its 16:9 though..... why is it not 16:10?!
  17. thetrashcanman
    18 Nov 2010
    because unfortunately 16:10 is a bit of a niche market, apart from for professionals, I'm sure goodbytes will be along shortly and go into MUCH more detail.
  18. thetrashcanman
    18 Nov 2010
    Oh and thanks for the info chum :)
  19. GoodBytes
    20 Jan 2007
    longweight PM'ed me, I am looking into the suggestion posted here.
  20. donok
    donok Every Little Helps .....
    16 Feb 2011
    I got 3 u2311h for £495 brand new off eBay. They look pretty amazing on crysis 2 but I am using dual 580s in SLI to run it
