Displays £650 display set up
Discussion in 'Hardware' started by longweight, 18 Jul 2011.
  1. GoodBytes
    20 Jan 2007
    The U2711 is 16:9, but of course a much higher resolution.
    Essentially, your choice is:
    1x U2710 (16:9 - 2560 x 1440)
    or
    2x U2410 (16:10 - 1920x1200)
    Well it depends on you.
    1 monitor setup is better for gaming, as you don't have any multi-monitor lack of support (game is only on 1 screen, so the other screens still shows the desktop).
    2 monitors setup will provide you with better multitasking, and it's 16:10. More and more games support multiple monitors, but not all. Also, your GPU will run hotter as it needs more speed to sync both in drawing, so, depending on your cooling solution, a bit louder system, unless you attach each monitor on separate graphic cards.
    Else then that, you have the U3011, which is the U2711, but the 16:10 format.
    It all comes down to, what is more important to you.
    Of and you have to consider that SD quality videos, will look even worse on the U2711/U3011, as, you guest it, needs to stretch it even more to fit it when you full screen it.
    To me, both setup are perfect, and excellent for what you paying for. It's really preference.
  2. longweight
    7 May 2011
    Thanks Goodbytes for the Pm and the information above, just been on the phone to Dell Uk and they are going to send me a quotation with the best price....
    I think one large screen will be better for home use as I rarely multi-task! The main reason for wanting 16:10 is to fit more on the screen, you don't get all that much on a 24" 1920 x 1080 monitor (I use 2 at work).
  3. Parge
    16 Jul 2010
    They do, they'll got from stock 2D clocks (say 50mhz) to semi 3d clocks (say 400mhz). Take a look in GPUz.
    also @ Longweight, could you let us know what your quotation is?
  4. longweight
    7 May 2011
    It was a home use quotation not a small business one which was my mistake.
    £838 list -5%
  5. longweight
    7 May 2011
    Seems to be lots of concern about input lag on the U2711 and nearly all reviews say that it is not ideal for gaming.
    What other alternatives are there?
  6. wyx087
    15 Aug 2007
    what lag?
    don't get any lag problems, and i play pretty fast pasted FPS games online. (though not competitively)
  7. longweight
    7 May 2011
    Most reviews mention that you can detect input lag in first person shooters:
    TFT Central review
    anandtech review
    But if you own one and can't really detect any lag then I will believe you!
  8. Guest-44432
    Guest-44432 Guest
    There seems to be allot of bad reviews on monitors which are pure awesomeness! (Don't believe everything you read!)
    This is why I done my review of the LG IPS231P-BN, as some reviews sites stated it had bad lag, and yet I have not had any, and many people who have owned the monitor will state the same as me.
  9. wyx087
    15 Aug 2007
    problem with review sites are that they review 120Hz TN monitors and then expect IPS to feel the same. truth in the matter is that yes there are minor lag difference, it's something you got to sacrifice. the better image quality, the larger input lag.
    TN is terrible, but fast. IPS is good at colours and have reasonable response time. PVA has extremely beautiful colours, but has slow response times.
    IPS will never be as fast as TN, but it's good enough for casual gamers who are not playing split second twitchy shooters.
  10. longweight
    7 May 2011
    Well I just wanted to check to see if it was an issue! But probably play similar games to you guys, L4D2, TF2, Dirt 3, BF3 when it comes out, Just Cause 2 etc... so I guess it will be fine :)
  11. GoodBytes
    20 Jan 2007
    Also to note, that IPS panels did some huge improvement in speed and lower input lag over the last couple generations. So people still assume that IPS is a big no for gaming, and TN is the only option, but that is simply not true.
    I don't know about you guys, but I play games for entertainment, and to have a blast... not to get frustrated in trying to be best of the best. I die a lot in multi-player games.. so what.. I am having my fun.
  12. Guest-44432
    Guest-44432 Guest
    Same here! Although I do own on RB6V2...
  13. longweight
    7 May 2011
    Well if I suck at any fps in the future I will have a damn good excuse!
  14. GoodBytes
    20 Jan 2007
    LOL!
    I blame my non-gaming class printer. Latency is too big, and I don't have 20 macro keys,
  15. longweight
    7 May 2011
    Hey you have your laggy IPS panel too!
  16. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Get 3 of anything if you can. Seriously, you'll never ever go back once you play in triple.
  17. GoodBytes
    20 Jan 2007
    Hmm no.. I would prefer a descent monitor than 3 crappy ones.
    At least with 1 I can enjoy better my computer.
  18. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Core jumps briefly to 400 and within a few seconds all clocks go back to 2D 50/67.5/101
    I'll say it again: two monitors makes no difference to my GPU clocks or temps LOL :thumb:
  19. longweight
    7 May 2011
    Are you sure?
    :p
  20. LennyRhys
    LennyRhys Oink!
    16 May 2011
    No, let me go and check :D :D
