Build Advice £650 PC - Advice Needed!
Discussion in 'Hardware' started by Pliqu3011, 10 Aug 2009.
  1. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    OK, I'm looking (see the topic title) for a new PC for £650 (again, see topic title) to £680 max!
    I've absolutely no idea what components to use...
    -I want to build it myself :)
    -I use my system for almost everything: Gaming, Photoshop, video editing, Cubase, etc.
    -I have absolutely no components lying around (that I don't use for something else...)
    -I'd love to overclock (if my budget can get me a system that allows it)
    -No monitor, keyboard, mouse or any other peripheral needed!
    -No OS needed!
    CPU:I think I'll need a quad-core, Intel or AMD: I guess an i7 will be too expensive for my budget :sigh:...
    Graphics card: I'll play most games at 1680 x 1050 (or maybe even 1920x1080)
    Motherboard/Harddisk/RAM/PSU/CPU cooler/Optical drive/Case/etc.: I have absolutely no idea...
    PS: Yes, I've read the Buyers Guide, but I don't know if it is right for me:confused:...
    PPS:pardon me for my English, it's not my native language...
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
  3. Guest-16
    Guest-16 Guest
  4. Elton
    23 Jan 2009
    Then 12 hours we shall wait.
    And that is quite a budget, although you'll probably end up impaling yourself when you realize how much the extras cost.
  5. jrjn_kiss
    jrjn_kiss What's a Dremel?
    9 Aug 2009
    If you want core i7 i would recomend the following f5rom www.scan.co.uk:
    Asus TA-861 Black midi case - £18.35(cheap nothing flashy)
    Be Quiet Dark Power 650W - £103.95
    Samsung Optical DRive - £15.51
    Gigabyte GA-EX58-UD3R - £138.20 (One of the fastest and most overclockable i7 mobo)
    Intel i7 920 D0 - £206.05
    Titan Fenrir TTC-NK85TZ - £33.91
    Corsair XMS3 3GB - £48.42
    Asus HD 4770 512MB - £73.13 (A good sub £100 GPU able to play Crysis and low resolutions)
    Hitachi HD 320GB - £32.19
    Total £682.51
    This setup has a lot of overclocking potential, but as the budget is tight and the need for a case etc, cuts had to be made.
    I would reccomend the following again from www.scan.co.uk:
    Samsung Optical Drive - £15.51
    Biostar Tpower I45 - £101.76
    Itel core 2 Duo E8400 - £123.37
    Arctic cooling Freezer 7 pro - £14.82
    Corsair TwinX XMS2 4GB - £43.53
    Palit 275 GTX 896MB - £160.97
    Total - £627.16
    The setup again has lots of overclocking head room and as it is under budget i would reccomend you choose faster Ram and a faster Gpu, but thats up to you.
    Hope this helps.
