Notebooks £800 to spend on a laptop HELP!!!!!
Discussion in 'Hardware' started by Neoki, 21 Sep 2006.
  1. Neoki
    Neoki Minimodder
    26 Oct 2004
    Hello, i am looking to buy a laptop that will be not only used for work such as word processing but also gaming. I have seen some second hand xps' but they were a little bit old.
    Any ideas?
    Looking for a nice dedicated Hard drive
    at least 1 gb of ram and 100gb hdd.
    Cheers
  2. alastor
    alastor Minimodder
    6 Sep 2004
    Which games will you want to play, and what sort of size laptop were you looking at?
  3. Neoki
    Neoki Minimodder
    26 Oct 2004
    Well all the latest and I am not to fused about the size. Just best for £800
    Cheers
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    You can get a Dell Core Duo with 1Gb of RAM, 60Gb HD and ATI X1400 for £796. Thats about the best I can find.
  5. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    There's the Rock Pegasus if you are willing to spend an extra 50 quid it has a geforce go 7600 256mb
    Intel Core 2 Duo T5600 1.83GHz 2MB
    WXGA (1280 x 800) X-Glass
    NVIDIA GeForce Go 7600 256MB
    1GB DDR2 667MHz (512MB x2)
    80GB 5400rpm SATA
    8x +/- Dual Layer DVD Writer
    Windows XP Home
  6. alastor
    alastor Minimodder
    6 Sep 2004
    The Pegasus sounds like a good deal...to be able to run newer games at native res and any sort of detail levels at a respectable frame rate, you'll need at least an X1600/7600. The 7600 in the Rock should do a decent enough job, but a GT would be perfect...will see what I can find.
    Actually I cant really find anything better... :blush:
  7. KMS-oul
    1 Aug 2002
  8. TheSaladMan
    TheSaladMan What's a Dremel?
    15 Sep 2006
    Oh yea because those intergrated ones can be a bitch :hehe:
    Seriously though, have you considered the Acer Aspire 5602? on shoplaptop.co.uk it's got a 120GB hard drive and 1GB of ram, and it's dual core, for £679.
  9. kenco_uk
    28 Nov 2003
    Looks good, but it's only got a X1300 ATi card, which compared to a 7600 would be seriously lacking.
    Pegasus seems the one to go for so far.
    Found another of similar ilk on ebuyer:
    http://www.ebuyer.com/UK/product/110606/rb/21953738149
    Toshiba with a NVidia 7600, 17" screen (1440x900), Core Duo, free upgrade to 1GB Ram, 60GB hdd.. £799.99 delivery'll probably be about a tenner.
  10. Neoki
    Neoki Minimodder
    26 Oct 2004
    Yeh that seems to be one of the best for money. Aparently the battery dont last long. Still looking
  11. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    See what's available on your budget from the likes of Laptops Direct +/or Laptop Shop?
    They both have a pretty good range of notebooks - from a wide range of respected manufacturers (Acer, Asus, Sony, Toshiba etc) - at prices to suit all budgets :thumb:
    You should also consider an HP Pavilion. I've got a Pavilion ZD8228EA, and I honestly can't rate it highly enough:cooldude:
    It looks good... it's nippy... it's quiet, it's light... and it's comfortable :rock:
  12. Guest-16
    Guest-16 Guest
    Dude, do you work for laptops direct? I can point out about 3 posts where you've highlighted and coloured their names. It just seems strange, I mean, you dont highlight or suggest anything else.
  13. DougEdey
    5 Jul 2005
    He always highlights links in a different colout.
  14. Hazardous
    21 Jan 2004
    :confused:
    I can point out the very same number of links to the Laptop Shop as well Bindi! I don't think I've ever linked to one, without including the other in the same post?
    And the simple reason I don't suggest other sites, is 'coz I don't know any!
    If you know of any other [good] online laptop shops though... I'll be happy to include them as well, next time I'm advising someone where to look for laptops :idea:
  15. Guest-16
    Guest-16 Guest
    :D Just wanted to know!
    It's just like a load of threads in here and it's always "laptop shop" in bold and coloured like you're jumpinig around (in my mind) like "student deals" or "this one here" makes a little blinking light turn on, on my "mod alert" panel. No stress, twas only a little question and a lot of poking in the side along with a naughty grin :naughty: You have 600+ posts, you're obviously not just here to pimp.
    In hindsight I should have included smilies :):)
  16. Neoki
    Neoki Minimodder
    26 Oct 2004
    Like i said it needs to be a 7600 or equal.
